Question about Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62"has no picure but has sound
I too am having the same problem on my 62" Toshiba. The red light stays steady, and the green light blinks 9 times then repeats.  I changed the blulb and it still dosen't work.  But, Every once in awhile I get lucky and turn the TV on and the picutre comes on. I called a repair guy who came out and told me that the light engine is bad and wants to charge me $600+ to that my only solution?? Please help! This TV is only 3 years old. Bought it at Costco and the repair guy told me that he called Toshiba and they said they would not honor the warranty on any of the parts. Just don't want to get taken!! Thanks! Kerry
  • 3 more comments
  • Anonymous Nov 12, 2007
    wow! I'm having the exact same problem. my 62hmx84 is also approx 3 years old and I too just replaced the bulb about 5 months ago. please let me know if you find any other solution.
    thanks, wacko jacko
  • Anonymous Nov 23, 2007
    picture suddenly out and red light with blinking green,no picture, off and on sound
  • Anonymous Nov 29, 2007
    Same problem. haven't replaced anything yet. hoping there is something else (approx 2 yrs. old)
  • jaybones Dec 02, 2007
    same as described
    same problem
It could be the lamp ballast
Posted on Oct 20, 2007
Have sound no picture?
if the fan is cutting off and ON there is a problem with your power supply unit.
and this may also affect your other systems on the unit
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
Just replaced bulb and the tv still does not work? the green light flashes 9 times and the red light is solid
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Mitsubishi WD-52725
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Bad lamp?
If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here:
Jun 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
No picture
If the red light stays steady, and the green light blinks 9 times then repeats, it is most likely the lamp #23311083A about $200. Otherwise, if a cooling fan is not working, it could possibly cause a shutdown problem. You can't always tell a bulb is bad by looking at it. Another possibility is the lamp ballast, but I would try a new bulb first.
Feb 10, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
