Question about Pioneer PRO-510HD 53" Rear Projection Television
Loose Sound and Picture very now and then, but TV stays ON
My set was installed in mid-2001, though when i talked to pioneer about this model number, I was told that this set was manufactured in 1999!
The set ran nicely and still works well most of the time, but in last four or five months, it has devloped the following problem.
Every few days, my Pioneer Elite PRO-510HD looses picture and sound, but the green light on the bottom stays lit! Neither come back if I just live the set in that condition. But, if I turn it OFF, wait for about 10-15 minutes, the TV operates with picture and sound and acts normal -- until the problem occurs again.
Someone told me that this problem could be due to a bad Deflection Board! Can some one please tell me what a Deflection Board is and what would cause my problem and how I'd go about fixing it.
Thank you so much.
  • 4 more comments
  • Joerepair Nov 08, 2007
    My probelum the same as pkorisa's
  • pciaccio Jan 18, 2008
    I have the exact problem as pkorisa. Did she ever find out about the deflection board? I am having a hard time finding a service provider to work on a projection TV.
  • reloscott Oct 15, 2008
    I am having the same problem. did you ever find the problem?
  • kbsw3 Nov 24, 2008
    this is exactly my problem.... any answers yet?
    have exactly the same problem.. any answers yet?
  • chezprovence Dec 04, 2008
    On occassion, my TV will regain video and sound with the green light on ... but only with a very loud pop as it restores itself.
Check out www.manualsparadise.com There are service manuals available for download. They start at $7.95. That might point you in the right direction.
Posted on Nov 07, 2007
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Right speaker perfect. Left speaker sounds like someone is talking through a kazoo.
Hello
Just check the left side speaker for its voice coil trouble. If voice coil has got damaged, this kind of fault will occure. If so replace the speaker with an identical one, both in size and impedence [ie resistsnce in Oms]. Connect an other good speaker of any type to the left speaker wire, and check whether the sound though it is perfect or not. If it is perfect, there is no doubt that the speaker inside the TV is damged. If the connected outside speaker also gives disorted sound, the Audio Output IC inside the Tv is faulty. Have to replace it with same type and number.
Before doing all these, go to the sound control section through your TVs menu options, and be sure that the balance control is set to mid position.
Ok.
Jan 19, 2011 | Samsung LN32A330 32 in. LCD TV
Sound is not coming but picture is ok in philips 21 RF vardan tv
sound is not coming but picture is ok in philips 21 RF vardan tv
Dec 16, 2009 | Philips 32PW6506 32" TV
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Pioneer PRO-510HD 53" Rear Projection Television Logo
170 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
