Question about RCA 27V520T 27" TV
RCA TELEVISION I recently purchased a "demonstrator" from a hardware store. Every time I turn the TV on, the setup menu appears, and I have to cancel it manually with the TV remote. I called the store, and they had to do the same thing! Now, when there are a bunch of different people, who I think didn't really care, doing this, it's not a big deal .... but in my living room, it's a major pain in the butt looking for two remotes, one used only to get rid of the setup menu! I've followed all the directions in the manual, as near as I can tell, but there is nothing "specific" about this problem. PLEASE HELP !!! Thanks; GRAMMA
All you have to do is run the auto channel dectection in the setup menu and when it is finished it would have a check in a box indicating what all channels it has found after this menue would never appear again.
Posted on Oct 21, 2007
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
Mar 11, 2016 | Televison & Video
My rca shuts itself off after 5 mins
1 press setup / tv menu in tv mode the tv menu screen will appear
2 press the arrow up or down arrow to select setup than press enter
3 press up or down arrow to select auto-shut off and turn it off
Mar 03, 2013 | RCA L32HD32D 32 in. LCD HDTV
My convergence will not line up right
if you press menu then scroll down to setup then enter the setup menu does the auto convergence adjustment option still appear under the setup menu options or has it disappeared?
Feb 11, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Recently purchased a rca tv model F35317, parental code from previous owener locked need to bypass
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Hope this helps you out. Thanks
Jan 03, 2011 | RCA F35317 35" TV
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
Whenever i turn off the mains, i get a Demontration message after power on.
From the manual:
Demonstration Mode
DISPLAY THANK YOU”
Press ?/1 to turn the receiver off while the above message
To view the demonstration
Hold down SET UP and press ?/1 to turn on the power.
Notes
• Running the demonstration will clear the receiver’s
memory. For details on what will be cleared, see
“Clearing the receiver's memory” on page 15.
• There will be no sound when the demonstration mode is
activated.
and...
Note: If the AC power cord is disconnected for about two weeks, the receiver’s entire memory will be cleared and the demonstration will start.
Mar 17, 2010 | Sony STR-DE445 Receiver
Can't turn off closed caption & not its not on the TV menu
I went to menu, special features. then select analog CC and selected OFF.
Dec 27, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Bowed at top and bottom
No amount of cleaning is going to fix this problem, Go to menu look for setup see if you have convergences listed on menu if so try auto converge. If convergence is not on menu then you have a open fuse next flyback transfomer FL231 middle fuse.
Nov 10, 2008 | RCA D52W19 52" Rear Projection Television
RCA- R52WH74
I had the problem with my rca looking like it was in 3d. anyways, I read this post and ordered the part ($3.79). did the soldering and TV works perfect now. Txs so much for the info on how to fix the problem. I was so worried it was going to cost a ton to have someone repair the TV. Much appreciated!
Feb 21, 2008 | RCA R52WH73 Projection Television
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
