How to create a bootable disc using dos environment
Tell me how to create a bootable disc using the dos environment
best regards.
  • 31 Answers
First of all you need to install the disc creator (eg:- magic iso maker) , then you need a win98 disc & insert it to your drive & open it bootable image using magic iso.then save it & add your desired files to your disc 7 burn it using recorder.
best regards
please vote.
Krishan
Posted on May 11, 2009
Tip
How to Flash a System Bios using a diskette or a CD
Not all PC models have the option of flashing the bios under the windows Graphical User Interface (GUI) environment. There are some that their manufacturers only give diskette option which will involve using the DOS (Disk Operating System) environment. Recently, the CD drive is also given as an alternative since most PCs now do not have diskette drives. Well in both cases, it will involve creating a bootable diskette or CD. Here's how to go about it:
First, you would have to visit the manufacturer's website and carefully check and download the latest driver files for your system model. Also, you would have to save the instructions for reference when necessary. If you are downloading for a diskette, you would have to download the driver files for diskette (they are smaller than that of the CD). Now, the next thing is to create a bootable diskette so you can copy the downloaded files to the diskette. The easiest way of creating an MS-DOS bootable diskette is by visiting www.bootdisk.com/bootdisk.htm, download an image (you can select 'Windows ME, Custom, No Ramdrive'), and follow the instructions to create your own bootable diskette. If the bios files you downloaded are zipped, you would have to unzip first so you can have access to the actual files and copy them to the bootable diskette. If you are downloading for CD, then you would have to select the one for CD if available. Normally, with the CD, an application is added to automatically burn the bootable CD. You would have to be sure your CD drive is a burner or writer. Take note of your drive letter (whether E:, F:, A: etc). Now you are ready to lunch.
If you are using a laptop, be sure to have your battery and adapter connected and if it is a desktop, then be sure to have a backup power like a UPS. Restart your PC and be sure to set your PC to boot from Floppy or CD depending on which one you are using. Now the PC will boot into a DOS environment. If the main application does not lunch automatically, you would have to lunch it yourself. In this case, you will see a drive letter and a blinking cursor. If the letter showing is not that of your drive, then you would have to enter your drive. This is an example of what to type if say we want to enter drive 'E';
c:\>e: (then hit the enter key)
e:\>
In this case, we were in drive C: and we moved from C: to E: by typing 'e:'. From the instructions, you will know the main file to lunch. This is an example of lunching a file with the name 'bios.exe' in drive 'A';
a:\>bios.exe (then hit the enter key)
In this case, we were using drive 'A'(normally the case with diskette). If it were to be drive 'E', it would have been;
e:\>bios.exe (then hit the enter key)
When this is done, you follow the instructions step by step to successfully complete the procedure. When done, you can check your bios settings if necessary.
Hope this was helpful and all the best.
on Feb 19, 2010 | Computers & Internet
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
4. Click Start
hope this helps you
Oct 19, 2011 | Computers & Internet
System32\config\system is corrupted. I want to boot from a flash drive. How it is made, the flash drive?
I recommend you to boot from a Windows CD and use the 'repair' option.
Anyways, Flash Drive is a Universal Serial Bus - Mass Storage Device (USB Memory Storage Device) also known as Pen Drive in common.
  • To install/Repair OS using a Flash Drive, you need to follow these steps
Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ ' Alt: mkbt20.zip
  1. Put a bootable floppy disk in your A: drive or create one using Windows.
  2. Download mkbt20.zip and unpack to to new temp folder you create.
  3. Go to the temp folder.
  4. Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type:  mkbt -c a: bootsect.bin
  5. The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created.
  6. Format the flash drive in FAT or FAT16.
  7. Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type:  mkbt -x bootsect.bin Z:
"Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly.
Now you should be able to copy the utilities you need to the pen drive.
If you need more Methods/Options, you can check BootDisk
Aug 11, 2011 | Computers & Internet
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
Aug 11, 2011 | Dell Dimension 4700 PC Desktop
Than you in advance for any and all help pertaing to my issue. Problem: 3-4yr old HP laptop. Did have Win XPsp2 on it. HDD went bad. Used Barts PE to create bootable cd-rom with half working Win XP, but...
Why do it the hard way? If your HDD is bad, most probably the system files are corrupted too and getting/making a bootable CD from the HDD files is just wasting your effort. If you laptop CD/DVD drive is still good, then use the options below: -
1. Go to any torrents site download "hp oem xp" disc from the site & burn the bootable image to a CDR.
2. Go the the Hp support Site & download the XP drivers for your Laptop model.
3. Then you can do a new installations on your Laptop.
Hope it helps.
Nov 15, 2010 | Microsoft Windows XP Professional
How to create a bootable usb pen drive
please download a software (Eg:- bootflashdos) from softpedia.com.
Using that bootflashdos program you can create a usb pen drive as a bootable device.
best regards,
Krishan
May 09, 2009 | Electronics - Others
DOS for gateway laptop model ML6720
Pls try to download boot98se.exe and thereafter it will automatically install itself to a blank diskette. That would then be bootable and usable as a DOS boot disk. If you are running some other Operating System, this page may help you with making a bootable DOS disk.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 31, 2008 | Gateway Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
