Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
New battery and cables motor will not turn over
New battery but motor will not turn over
  • 246 Answers
Hello:
If this is a OHV (Over Head Valve) Engine, then Set the Valve Clearance.
The Problem Sounds like the Compression Release is Not Operating Correctly.
Setting the Valve Clearances will Correct the Compression Release Problem.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Pickup will not start. have new battery still nothing is there a fuse or relay to start motor
if it cranks over-it may be an ignition system fault/ if you turn the key and nothing happens at all with a good battery-it may be a bad starter motor-the starter motor has a very small wire connection not like the big fat starter motor battery connection-it is small and comes from the ignition switch - just apply 12 volts from the battery to that connector terminal and the motor will crank-key off it will not start-turn key to ignition on- it will start, so be in park and block the wheels and do not make a mistake
Apr 29, 2014 | 2001 Ford Ranger Regular Cab
Mazda 6 - Wont start, just clicking noise when key is turned. Battery seems dead, but radio etc came on??
radio don't use as much voltages (AMPS) as the starter motor. remove battery and charge up. remember radio is coded so you will need to put the code in after. negative lead first off the battery.also have ignition turned to number 2 then turn off and you have 30 seconds to remove the battery. if not battery starter motor solenoid has failed and a new motor is needed. check battery first.
Oct 11, 2013 | 2006 Mazda 6
Bmw gs 1200r adventure won't start with a new battery
Does the motor turn over when you hit the start button?
If you just hear a Click, click, click without the motor turning over, then your battery voltage is low and will need to be charged.
If your motor actually swings but doesn't fire up, chances are good that it is the fuel pump regulator that had blown. R1200GS 08 09 K25
Part number 16 14 7 720 776 is what you will need.
Mar 05, 2013 | 2010 BMW R 1200 GS Adventure
New battery, motor will not turn over
check battery power at starter with test light
Sep 11, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
99 kawasaki ninja EX250 motor swap for a 98 NINJA EX250 MOTOR
I would try charging the battery. Take it off and put it on a slow trickle charge overnight. Batteries usually only last 3-4 years if it is an acid battery.
Nov 27, 2011 | kawasaki Kawasaki Ex250f11 Ninja 250r...
New battery and motor wont even turn over 2002
hi
check the cables and the fusers
propebly you need to reprogam it
Jan 09, 2011 | 2002 Kia Spectra
My starter will not turn over the motor but the motor will turn over by hand on a 1990 suzuki samuria
possibly dead battery, starter motor or the solenoid switch on the side of the starter, test your battery for a charge if its got juice then theres something wrong with your starter you may need new coils and a solenoid or a completely new one
Oct 13, 2009 | 1990 Suzuki Samurai
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
113 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
