Question about Yamaha RX-V490 Receiver
PIN DETAIL IC TDA4867A
Pls Send Me intrnal stracture of IC TDA 4867A I
  • 4,234 Answers
The datasheet can be downloaded in PDF format from here:
http://www.datasheetcatalog.org/datasheet/philips/TDA4867.pdf
Dan
Posted on May 11, 2009
Tda 9370ps pls tell mr the Blue back pin
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Refer the circuit diagram. It is there. Surf the site with the number of IC " TDA9370 "as keyword.
Jul 03, 2015 | Televison & Video
Tip
Replace the kkz-12 power amp ic on kenwood car stereos
replace the kkz-12 ic[difficult to find expensive!]with the tda 7560!first desolder the kkz .have 27 pins.take the tda and cut the pins 1 and 25.replace the kkz with the tda now.let the pcb positions 1-2 and 26-27 pin empty.solder the ic put htc in the heat sink tight screws and check the unit!
on Mar 08, 2010 | Car Audio & Video
Only 1 channel has sound pin 18 has sound pin 15 no sound on ic tda 9859 please help
is that stereo sound? try adjusting the balance control in the remote control...
Feb 14, 2014 | Hitachi C21 F800S TV
DeawooTV Model DTC 2975 I want to know about vertical ic number.b,cos i can't fine out the number that ic is burn.
Hello
There are two mumbers used in Dawoo tv as vertical IC.
If used is a [9] pin one number is [TDA 8357J].
If used is a [10] pin one, number is [ LA 7848]
OK.
Jan 05, 2011 | Daewoo Televison & Video
TDA 8364
Look it up at nteinc.net
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Yamaha RX-V490 Receiver Logo
199 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
