Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Dish washer running with water in bottom only way to stop is open the door. It will not cut off when you turn it to the off
We just purchase home weeks ago.I opened the bosce dish washer found it had a musty order.The following day i ran a dish washer agent,which didn't work.clean the washers filter noticed green algee.
Put two cups of bleach in it and run it on a long and hot wash. The best way to stop the odor is to use it regularly and leave the door open for 15 minutes after you use it so it can dry out a bit. There will always be some water in the bottom in the pump.
Sep 23, 2017 | Cars & Trucks
Samsung dish washer won't stop running event with the door open no leaks no water anywhere pump pushes water out drain hose
if you can hear it running even with door open its probably in a fault mode as this the only circumstance in which it will run with the door open, what you are hearing is the drain pump and its doing that because there is a leak in the base of the machine setting off its flood switch, if you pull the dishwasher out and lean it back you will see water run out the bottom, then you need to find where its leaking from
Dec 26, 2016 | Samsung Washing Machines
Why does my dishwasher most of the time not desovle the dish soap
make sure when you load it that nothing is stopping the soap door from opening all the way,, most common mistake is loading a cutting board or tray in the front of the lower rack
Nov 20, 2015 | Frigidaire Dishwashers
Lots of mold around rubber gasket; unable to clean off; odor from mold; water in detergent trays; maybe some water leaking from washer; washer bought in 2008
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
Feb 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
White film is all over my inside of the dish washer & dishes
This sounds like excess soap or not enough water. You may also have really hard water.
Turn on machine wait until it starts running see how much water is inside. there should be a 1/2 to 1" +/- in the bottom but not enough that the wash arm would be touching and not enough that the door would be leaking when you open it. This could also be a circulation problem set wash arms a certain way and observe that they have moved when you open after running for a minute or 2.
Please let me know if I can do anything else to help.
Apr 13, 2010 | GE Dishwashers
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 | Dryers
Dishlex global 300 - dish washer door won't open
I have the some problem toooo!!
I have turned it off and on from the power point and run the cycle again on "normal" and on "rinse" .
Next step will be to cut the screws with a hacksaw , remove the the dishwasher from the cupboards, remove the bottom tray and give a good clean underneath .
Feb 08, 2009 | Dishwashers
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Water doesn't enter dish washer
hi. thanks for the question . i would replace the water valve located behind the bottom kick plate .replace water valve. thanks the appliance doc
Oct 05, 2008 | Kenmore Dishwashers
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
23 people viewed this question
Top Baumatic Dishwashers Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
