Question about Uniden Cordless Phone
Can I change when the answer phone kicks in so my fax doesnt beat it. I have extended the fax to the max of six rings
  • 64 Answers
SOURCE: how to extend rings on phone before answering machine starts
Hello, here is the link to the manual for that model:
http://www.uniden.com.au/resources_main/pdfs/XSA660.pdf
The information is on page 28
Posted on Mar 06, 2009
landsend
  • 1066 Answers
SOURCE: Need more rings before answering machine starts
some phones have switches on the base unit, sometimes on the back or bottom.  some phones you need to use the set up procedures to set this feature.
Posted on Mar 22, 2009
KingDWS
  • 1606 Answers
SOURCE: How do you change the number of rings before
Here is how to kill two birds with one stone.
http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0
That is the page for Uniden DECT phones. www.uniden.com.
There are 6 pages to flip through and all you need to do is look at the picture for you phone. Click on it and it takes you to the phones page. On the upper right sid there is a link to download the owners manual in pdf form. Unfortunetly I can't tell your model from the information so I can't tell you the page or how to do it. Hopefully the manual will get you sorted out.
Posted on Mar 23, 2010
guru_fixya
  • 944 Answers
SOURCE: The answering system answers after two rings how
Press the answer button on the base (answer off), this will give you up to 15 rings before the answering machine turns on and takes the message.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
  • 102366 Answers
SOURCE: how do i change the rings before the answering machine answers on the power max 2.4?
Since you neglected to specify the model of your Uniden PowerMax 2.4GHz phone, I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Oct 02, 2012
How do I extend the ringtone time of incoming calls on binatone lifestyle 1910
Most of the newer phones have a feature that quiets the ringtone when you touch the phone or move it. You can deactivate this feature in the settings menu. I hopes this helps you..
Nov 25, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
How to extend ring
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
Aug 18, 2014 | Binatone Lifestyle 1910 Twin Cordless...
I can send a fax without any problem, but am not able to receive. I have set it to send after 3 rings, but the phone rings and then my answering machine comes on. I just turned my answering machine off. ...
Set the answering machine to answer incoming calls before the printer does. For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls after five or six rings. Also, make sure the fax line is plugged into the Line port on the back of the printer and the fax settings are correct (phone number, pick-up on rings, etc).
May 12, 2011 | Lexmark X5075 InkJet Printer
When I get a phone call the fax kicks in. How can I adjust the setting to turn on only if a fax sound comes in?
You can add more rings to answer, but the only real way is to get distinctive ring from your phone co. or a separate line for fax. When you change the setting to manual receive, you have to answer yourself and if you hear fax tones you hang up and press fax start, or receive.
Oct 12, 2009 | HP LaserJet 2840 Printer
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Can send but not receive faxes.
Fax machines won't work reliably on a digital phone line.
Feb 02, 2009 | Office Equipment & Supplies
Fax answer phone line
You set the machine up in the answer/fax mode, when a fax is coming in you have to press 9 on the phone to make it receive the fax if you pick up the receiver when it is a fax call.
You can also change the number of rings to answer a fax, I think the max is 7 rings.
Dec 20, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
I HAVE A HP OFFICE 4315 ALL IN ONE PRINT.. I CANT GET FAX AUTOMATICALLY
Set to fax, ring it from another phone, what happens? Count how many times it rings before answering (if it answers)
Do you have other things attached to it?
Where is the phone line attached to socket marked line or ext?
Do you use Broadband? Has the fax got filters attached before it?
Are there other phones in the house or has the fax a dedicated line?
DONT YELL
Oct 20, 2007 | HP Officejet 4215v All-in-One Printer
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
