Can anyone help me? I have an Archos 705 wifi and have been having probelms with it. When i start it up it hangs on the startup screen. I can see that the hard disc is running but nothing happens. If i try to connect it to a pC i get the same thing. IO have tried hitting the mater reset on the back but that does no good. Any ideas?
  • hell0 May 11, 2009
    Thanks for the info , however it wont let me get to the stage where i can see it on my PC. When you turn it on it hangs at the logo stage so i cant get to the stage where it asks is i want pc mode. Because i cant do that i cant see it as a drive on my machine. The hard disc is defiantly spinning but its just stuck in the boot up on the archos logo.
    any ideas?
    President:
  • 987 Answers
Http://update.archos.com/5/a705/a705_r2.1.04/firmware_a705.aos
first download above firmware..
How to install a firmware. Firmware is another name for Operating System (OS) or System Software. Below, you will find the instructions and the latest software to update your specific ARCHOS device. You do not have to install all the updates, only the most recent one. Each update takes into account all the previous updates unless specified otherwise.
Gen 5 Wifi Devices:
If you have an Archos WiFi device connected to the Internet, you can update your device directly by going to menu>Firmware & Plug-ins>Online Firmware Update. Press OK and then follow the on-screen instructions.
Other Devices:
Step 1. Download the firmware to your computer
When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. Wait a few seconds for device detection
Step 4. Copy and paste the downloaded firmware (.AOS file) to the "root" of your ARCHOS device.
  • Case 1: Your Archos is detected by your computer as a Hard Drive ( E: for example ) in Windows Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: Your Archos device is detected as a ‘Device’ in Windows Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3. Your Archos device is detected as a ‘Device’ in Windows Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various Archos folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (Windows Device connections) or use the "safe disconnect" green arrow icon (Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Generation 5 products: Once you disconnect the USB cable, the device will recognize the new update file and invite you to install it. Follow the on-screen instructions. If it does not suggest an update, this means that the .AOS file did not get placed on the “Root” of the device.
Generation 4 products: From the main ARCHOS screen, click on the "tab" button to show the settings screen. Select the System icon and then click on the Update Firmware button.
Other products: Go to the settings and open the icon “System” where you can find the Update Firmware button.
Note: In all cases, your new .aos file must not be in a folder within the Archos device. The ARCHOS expects to find the update file on the “root” of the device. You can verify this by using the file browser on the device.
Posted on May 11, 2009
  • 854 Answers
You can try to update the firmware...
Gen 5 Wifi Devices:
If you have an Archos WiFi device connected to the Internet, you canupdate your device directly by going to menu>Firmware &Plug-ins>Online Firmware Update. Press OK and then follow theon-screen instructions.
Other Devices:
When you download the update file, your browser may warn you that thefile 'could be harmful'. This is normal because browsers are notfamiliar with files that have a .AOS extension and suspect that theycould be malicious. These files are not harmful to your computer.
  • Case1: Your Archos is detected by your computer as a Hard Drive ( E: forexample ) in Windows Explorer. Paste the update file directly onto theARCHOS hard drive icon.
  • Case 2: Your Archos device is detectedas a ‘Device’ in Windows Explorer (not as a hard drive) and you seejust two folders Data and Media when you open it. Paste the update fileinto the folder called Data.
  • Case 3. Your Archos device is detectedas a ‘Device’ in Windows Explorer (not as a hard drive) and you seeInternal Hard Drive when you open it. Open this Internal Hard Driveicon and you will see the various Archos folders inside (Video, Music,etc.). Paste the update file into this area but be careful not to pasteit into any of the folders there.
Unplug the USB cable (Windows Device connections) or use the "safedisconnect" green arrow icon (Hard drive connection) in the system traybefore unplugging the USB cable.
Generation 5 products: Once you disconnect the USB cable, the devicewill recognize the new update file and invite you to install it. Followthe on-screen instructions. If it does not suggest an update, thismeans that the .AOS file did not get placed on the “Root” of thedevice.
Generation 4 products: From the mainARCHOS screen, click on the "tab" button to show the settings screen.Select the System icon and then click on the Update Firmware button.
Note:In all cases, your new .aos file must not be in a folder within theArchos device. The ARCHOS expects to find the update file on the “root”of the device. You can verify this by using the file browser on thedevice.
Here's the link for the latest firmware. Click here.
My archos is hanging every time i use the video
YOU MAY BE STORE MORE DATA. DUE TO THAT SOMETIME MEDIA PLAYER WILL HANG.OTHER YOU RESET UR ARCHOS.I THINK THAT MAY BE SOLVE THE PROBLEM
Feb 15, 2011 | Archos 705 WiFi Portable Multimedia Player
Can you advise where I can buy a replacement screen for my Archos 705
Hi
You can order the screen for the Archos 705 from this link---
Archos 705 replacement screen
Link 2
Hope this helps...
Daniel
Aug 28, 2010 | Archos 705 WiFi Digital Media Player
My archos 705 wifi will not hold its charge....help plzzz
There is a known issue with archos players since Gen 04 that causes them to discharge more quickly if left in their charging stations (DVR dock) after the full charge light begins to flash. If you charge the unit this way, your battery is probably toasted. Good news is that the 705 battery is user replaceable. Bad news is its over 40 bucks. Try newmp3technology.com or ebay for a good price on a new battery.
Sep 03, 2009 | Archos 705 WiFi Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
705wifi will not record from TV
Check your main unit clock and date setting. The recorder will not work if the date and time are wrong.
Jan 19, 2009 | Archos 705 WiFi Portable Multimedia Player
Battery difference between archos 704 and 705 (wifi) ?
I use the same batteries in both units. The only difference is the colour of the back plate and the label on the inside. Clone and extended batteries are different backs anyway.
Nov 17, 2008 | Archos 605 WiFi Digital Media Player
64 people viewed this question
 Grubhead
Grubhead
