Question about Holmes Products HAP422-UC Air Purifier
Red light on air filter
I have a red light on my air filter. I replaced the filter with a new one and the red light is still on .. can u help?
  • gnydan Nov 25, 2007
    DITTO
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Posted on Apr 10, 2009
There is a little hole between the red light and green light that can be missed easy but its there. inset a small needle or straighten a small paper clip and inset it in the little hole till it clicks . Then hold for a few seconds and the red light will blink and go out if your filter is clean.
Posted on Feb 12, 2008
  • Roy Ku Sep 30, 2012
    I tried resetting the filter and holding down the on/off button for a few seconds, but the red light didnt turn off. I put in a brand new filter too! Any other suggestions?
  • Daniel Gimness
    Daniel Gimness Oct 02, 2012
    Thanks!! It worked.
There is a little hole! just above it is a label that says "Filter Reset"
get a paperclip size pin and put it into the hole, you will hear a click
let the unit run a few minutes before it goes off. Make sure the filter is changed before attempting the above.
Posted on Oct 31, 2015
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Red filter light still on-
ok i'm not finding that model anywhere in my system. but one way you can try is look in your manual under troubleshooting. if you have gone through all of the troubleshooting. the best thing that i can suggest is call the manufacturer. if your still under warranty they should be able to replace the unit foryou.
Nov 04, 2008 | Bionaire BAP1175-U Air Purifier
Defender air purifier
If you have replaced your main filter you need to reset the red light. If you have not replaced the main filter you will need to contact your local filterqueen distributor. If you go to www.filterqueen.com they will direct you to your closest distributor and they can walk you through over the phone on how to reset your red light.
Feb 15, 2008 | Filter Queen Defender Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Red light won't stay off
    I do apologize for the inconvenience, the best way that i can tell you to fix the light is that there is a tiny pin hole on top of the unit. that's a reset button. you need a small needle or something that will fit in there. hold it down for about 3 seconds. your unit should reset. the light sometimes comes on with new filters cause it hasn't recognized that they are new yet. if that reset doens't work please let me know
    Aug 17, 2007 | Bionaire BAP825-U Air Purifier
    Red light
    Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file) If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work. If still flashing then there is a more serious, but probably fixable fault. Hope this helps - ask again if you need more info :)
    Apr 13, 2007 | Filter Queen Defender Air Purifier
    Red Light on front of Filter Queen Defender
    When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
    Mar 06, 2007 | Filter Queen Defender Air Purifier
    Holmes Products HAP422-UC Air Purifier Logo
    5,467 people viewed this question
    Top Holmes Products Air Purifiers Experts
    Michael Youngman
    Michael Youngman
    Are you a Holmes Products Air Purifier Expert? Answer questions, earn points and help others
