Question about Garden
It starts easily but runs rough and surges and then finally cuts out. It starts easily again.
  • 246 Answers
Hello:
This can be Caused by Several Things. The Most Common Cause is the Exhaust Port or Muffler.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • John C Bridgers Sr May 11, 2009
    Hello:
    Good Luck
    Respectfully
    jbridger (John)
I am experiencing a problem with engine running rough surging and cutting out. Tried all the obvious no result
engine running rough surging and cutting out Dj. A lot of things could cause this issue. First thing to do is have vehicle scanned for trouble codes, a good Tech. then can diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The dreaded engine surge Automotive Service Professional
How to solve engine hesitation and stumble problems on the90
Diagnose Engine Stalling Problem
Jul 28, 2016 | Cars & Trucks
1999 GMC Sierra 4.8l running rough now wont start
Recommend starting simple. If you suspect fuel pressure, it might be easier to start with replacing the fuel filter first, and checking fuel pressure at the filter while your there. It will give you a better chance to determine if the problem is at the pump or closer to the intake. If for some reason you have to replace the fuel pump...very common in this model truck because fuel gauge problems, the easiest way to access the pump is to unbolt the truck bed, block it up wood (Significantly easier than dropping the tank. I tilted mine to the passenger side), then you will have easy access to the pump. CAUTION!!! The connectors on the pump are brittle and break easily, especially in a vehicle this old. It's very difficult to get replacements, so take your time to prevent breaking fuel connections.
Dec 11, 2013 | 1999 GMC Suburban
Several problems. First, when I disconnect the battery cable to do any work, it idles rough when I reconnect the cable and start the engine, cutting off often. It smooths out in about a week. Also it has...
when ever you have to unhook battery the computer has to learn the engine all over again ,how much fuel ,how much air u get the picture -i believe u have bad oxygen sensors that are bad & maybe something else could be wrong thats why runs rough - cutting off maybe have a diagnose test done on it
Nov 01, 2010 | 2003 Chevrolet Suburban 1500
2001 Ford Ranger will not start easily, runs rough when does...Thought I had water in gas/fuel line freeze up...added fuel antifreeze. Got it to finally start had to use jumper cables. Drove truck would...
tune it up,plugs,wires,rotor and dist.cap if equipped,clean butterfly in throttle body,has carbon build up.use tooth brush and throttle body spray cleaner.when starting,never touch the accelerator,this will make it go in the limp mode or throw a code
Jan 31, 2010 | 2001 Ford Ranger Regular Cab
Rough Idle and then the veh cuts off
Have you tried cleaning the mass air flow sensor ? Use Qtip and carb cleaner to remove any gunk on the two wires that strech across the inside.
Mar 19, 2009 | 1999 Pontiac Grand Am GT
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
