Question about Dryers
Won't heat, is the element hard to change?
Maytag DE590 electric dryer will not heat. Is is difficult to change the element? Could it be a switch?
  • 56 Answers
Quite a job for a novice unplug unit take the two screws out of the front door panel at the bottom. pull out to about 45 degrees and you can see spring clips at top which should release as you pull up and out. give yourself some slack with the wires you can see how, set to the left, look down at the bottom right and you will see the heating element. there is a 1/4 screw in the very back top and two srews in front that hold the can in place, make a diagram of where wires go and remove them as you take out can. look for broken element if broken part #y303404 1-877-262-1479
Posted on May 31, 2009
Dryer spins but won't get hot. Bad heating element? If so , where is it located?
Check your circuit breaker. It may not be your dryer at all. 220 dryers run on two separate circuits one to run the motor the other to run heating element.
Sep 03, 2011 | Maytag SDE4606A Electric Dryer
I have a Maytag DE590 electric dryer that will not heat. I just replaced the heating element cause it was broken, it still won't heat. Any suggestions?
you have couple thermostats on the heater  check those and with electric dryers make sure you have propper voltage unplug your dryer and check if one leg has about 110 volts the other leg if it has 110 if yes than its with your dryer if not call electrician if you got questions feel free to write back
Jun 06, 2009 | Dryers
Dryer turns but doesn't heat. How do I troubleshoot?
Likely causes are:
- broken heating element
- burned/corroded connections in heating circuit
- blown thermal fuse / limit switch
- bad thermostat
If you don't have significant of experience with electrical appliance troubleshooting & reapir, this is a difficult task.
May 08, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
MAYTAG ELECTRIC DRYER DOESNT HEAT. CAN YOU HELP ME?
Without seeing it, and very little info to go on, let me ask this, does the drum turn?
If there is no heat, go outside and check the exhaust, do you feel air blowing out?
If you do, then the heating element may be bad or the switch that sends power to the element may be bad. If no air blowing out, then I do not know any further. At any rate, a service man must come.
Nov 16, 2008 | Maytag PYE2300AY Electric Dryer
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
