Leveled washer gets out of balance when load in spin cycle
I leveled tha macine and ran it empty on the spin cycle and it ran fine. When I put a balanced load of laundry in however it gets out of balance and starts moving all over the floor. What should I look for and what is the level of difficulty of the possible repair? Can I find a service manual on-line? All I have is the Owner's manual and an Installation Guide.
  • 3 more comments
  • lot2lern Oct 24, 2007
    The machine is an Amana ALW432RAW top loader.
    Yes I tightened the lock nuts and I got the machine as level as I can get it.
  • lot2lern Oct 26, 2007
    Comment by lot2lern, posted on Oct 24, 2007
    Solution #1posted on Oct 24, 2007
  • lot2lern Oct 28, 2007
    Comment by lot2lern, posted on Oct 26, 2007
    By Kawika-56
    Rank: Master
    Rating: 74.29%, 21 votes
    Did you lock the leveling legs by tightening the lock nuts?
    Add a Comment
    Add an Image to your post
    if you need the help of other experts, click here to repost your problemSolution #2posted on Oct 26, 2007
    By watugot
    Rank: Guru
    Rating: 89.71%, 70 votes
    A vibration problem is about the hardest thing to diagnose long distance but I will give you the most common things to look for.
    Shipping brackets and materials not removed from the machine. You should be able to move the basket around easily by hand. Go over the installation instructions and make sure everything has been removed.
    Leveling legs and lock nuts misadjusted or loose. You want the legs adjusted as low to the floor as possible. The higher it sits, the more movement it has.
    Weak floor. If you can stomp the floor and have pictures rattle on the wall, you will have vibration problems with the washer. If it is on a laminate hardwood floor, you will have vibration problems. These floors have too much bounce for a washing machine.
    The tub support to stiff causing too much vibration to be transferred to the cabinet or not allowing the tub/basket to return to the upright position so that it starts an out of balance spin. Put the washer into a cycle and let it agitate. Before it goes into a spin, open the lid and see if it is leaning awkwardly to one side. If the washer has some years on it, this may be your problem. If you remove the front panel you will see the thick washer the whole unit sits on. If it seems the unit is stiff , you may try spraying a LITTLE wd40 on the base it sits on so it slides easier, but just a little.
    Check these things out and you should find your problem.
    Thanks/Mike
  • lot2lern Nov 06, 2007
    Mike,
    The tub/basket is leaning to one side during the agitation cycle and starting the spin cycle out of balance. T tried spraying a little WD-40 on the washer but it didn't help, what else can I look for?
  • 290 Answers
Thanks/Mike
Posted on Oct 26, 2007
  • Michael  Lindley
    Michael Lindley Nov 06, 2007
    You will probably have to replace the friction ring and springs. The friction ring is the thick spacer everything is sitting on.
    It is not letting the basket return to center position.
  • Michael  Lindley
    Michael Lindley Jan 07, 2008
    lot2learn
    Just wanted to follow up on your washer and see if you got it fixed and what you found wrong,
    Thanks/Mike
I think this is a common Maytag problem. :( Mine is a commercial grade washer. My mother bought one becaused I liked mine so well. Last Christmas there was water in the area of the washer, husband scooted it out just a few feet to check for hose leaks (leak turned out not to be the problem.) Once washer was scooted back in place, vibration noise can be heard & felt all over the house (it is on a block foundation). This past week we put a new floor in our utility room. Washer was moved several feet. When put back in place, it now makes that terrible noise (concrete foundation, so it is heard but not felt throughout the house) Husband is in construction and things being level and plumb are essential to him. Getting the Maytags to relevel position has been the pits, but was finally acheived. Noise still remains on both machines. Luckily I can shut my utility room door to help quieten the noise. Just know in all the washers we've had in the 40+ years we have been married and in all the years my mother has been married, we have never had this problem with other brands....even moving across states. We will definitely NOT be purchasing another Maytag!
Posted on Aug 26, 2013
    Scholar:
  • 121 Answers
Are you sure it's a balanced load?  I would look at the type of clothes you have in it.  For example, jeans will hold more water weight than a soft blanket usually.  If you have a bunch of general clothes, and nothing unusual, prehaps you're overfilling it.  Try half a load, then 3/4 load, then a full load and see if the vibrating gets better or stays the same.
Thanks,
Erice
Posted on Oct 30, 2007
    Novelist:
  • 233 Answers
Posted on Oct 24, 2007
Washer gets out of balance during the spin cycle
Hello
Either the wash or laundry is unbalanced and moving to one side or the machine is no longer level on the floor.
Try putting in less clothes or seperate heavy from light.
Check all four corners of washing machine,while empty.For level,there should be two movable floor slider you can screw in or out to level machine.
Apr 06, 2011 | Crosley CAWC529JQ Top Load Washer
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My washer is perfectly level but during the spin
if you can make it rock by hand or by jumping the legs are not adjusted proper.it can also rock if the floor is soft... then get thick plywood under the washer ....11/2 inch should be good.you should try to balance the load put heavy things in first
Aug 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Sounds like a bangin when its in spin cycle need help please
If this is a front loading washer, the spider arm is broken at the back of the drum. Big bucks to repair this. You might as well buy a new machine.
May 23, 2009 | Frigidaire Gallery Supreme Series...
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Neptune FAV6800aww Will not go into spin
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Jan 22, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
436 people viewed this question
Top Washing Machines Experts
