Question about Gestetner DSm415pf Digital Imaging Sytem
DSm415pf Rex-Rotary Replace photoconductor error message one day after replacing toner.
The photoconductor has nothing to do with the toner. Photoconductor unit (Drum) is on a 45,000 copy cycle, and comes on when the count is reached. You don't have to replace the drum until the copy quality deteriorates. The machine will continue to work
Posted on May 11, 2009
Why is it indicating black toner is empty?
[Cause]
This may be caused by the Toner ID switch, that contacts the ID PWB on the Toner Bottle. The Toner ID switch has 4 wire contacts, if one of the contacts become crossed over this error may occur.
[Action]
Uncross and straighten the contacts.
If issue remains replace ID Chip Connector Harness [Part Number: G102 1120].
May 02, 2015 | Ricoh Aficio SP C410DN Laser Printer
Even I change the tuner but it's appearse the same masseage to put a new ink or tuner
If the copies look fine it is the toner hopper. It does not remove the seal from the bottle when closed. If the copies are getting light it could be the developer unit has worn out bushings and gears thus it does not turn properly making it impossible to sense the toner level and the constant add toner message. Usually you can hear noise if this is the case. Look at the oriface where the toner drops into the photoconductor unit from the toner unit. Is it full of toner coming out the top? If so, time to replace the PCU.
Nov 01, 2013 | Gestetner DSm415pf Digital Imaging Sytem
Our Gestetner DSm415pf printer has a photoconductor light on, needs to be replaced. Where do we purchase this and how do we find out the method to replace this. Manual? We don't have.
It's very easy to replace the drum unit. When you find Photoconductor unit there is a simple instruction on the box. You have to search for photoconductor unit type 1515 (also look for nashuatec, rex rotary, infotec or ricoh brands to see where you can find it on best price - 100EUR).
If your mashine is printing fine, there is no need to replace the drum. You can only reset PM counter display if mashine stops.
all the best
pifonski
Apr 07, 2011 | Gestetner DSm415pf Digital Imaging Sytem
What is replace color cpu toner?
Could the message have been "Replace color PCU (Type A)"? In that case, you need to replace all three color photoconductor units (order Printer Maintenance Kit Type 7100A).
I do not know of any Replace CPU error messages. I hope this helps.
Aug 18, 2010 | Ricoh Aficio CL7100 Printer
Install photoconductor
the photoconductor is commenly refered to as the "drum" .. its the cylindrical part that picks up and transfers the toner to the paper .. the error message might be telling you its time to replace the drum (they do wear out) or perhaps its not detecting the fact that it is in place .. the photo conductor drum is user replacable so it comes out without too much trouble .. sometimes its part of the replacable toner tank .. it would get automatically replaced when you change toner in that case .. be very careful with the photoconductor drum .. any scratches, finger prints or other damage will show up in the printed output .. dont expose it to bright light ...
Oct 01, 2009 | Epson AcuLaser C4100 Printer
Reset photoconductor unit gestetner dsm415
Zeroizing the counter Fotocondactor. The Sign - twinkle all lamps, in readiness not vyhodit.
1 To Press "copy" and include feeding with pressed кнопой. All indicators, except "Ready", light.
2 Release "Copy", press her(it) once again and keep until it is ed indicators "Toner" and "Paper" 10 sec
3 Release button. Switch off feeding, wait 15-20 sec, include once again
Sep 23, 2009 | Gestetner DSm415pf Digital Imaging Sytem
Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Apr 30, 2009 | Office Equipment & Supplies
Add Toner stuck on & Replace Photo Conductor Unit (PCU)
I suspect that it is the PCU causing the problem, and the message should clear once the PCU is installed and it (automatically) runs it's calibration cycle. Likely the toner auger gear has seized on the PCU, and broken. If the light does not go off after installing the PCU, then you may need a technician, as the toner motor may not be working, or there is a blockage within the toner hopper itself.....but again it is likely the PCU, especially if the toner bottle was empty when it needed replacement. Was it empty?? Did the machine work for a few days, or at least for a while? If so, it seems like too much of a coincidence that this problem would come up at this time.
Good Luck :)
Mar 18, 2009 | Office Equipment & Supplies
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
894 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
