Question about Vacuums
Eureka Model 4351 vacuum - motor runs but no sction.
The motor works but I don't feel any suction when I put my hand under the revolving brush.  Also if I let it stay on vary long it gets hot quickly and starts to have a burning smell.  I have checked the long hose and it is not clogged.  I have also unscrewed the plate holding the short hose at the lower rear of the unit and checked it for clogs.  It is also clear.
I am a renter and the directions for the unit are not here.  Can I download a manual for it including troubleshooting informatin
  • 3 more comments
  • Anonymous Nov 05, 2007
    took off bottom plate to check brush for obstruction nothing there, checked hoses no clog, checked and cleaned all filters still no suction but check again in a minute and it sucks......probably made in forien country
  • Jessie62 Dec 03, 2007
    I have fantom cyclone xt and have the same problem as above , checked the rear compartment air shaft and find no blockage. There is some suction thru the hose but there never was much there. The brush and motor run and I can hear the brush pick up stuff but it never seems to get the removal bin and the motor gets hot.
  • Anonymous Feb 24, 2008
    The motor sounds like it is working. The brushes are rolling. The vauum is not sucking.
  • Duckcleaner Mar 15, 2008
    I have checked all possible places for a clogged area but my vacuum is not picking anything up and has a burning smell. I no longer have the manual and need assistance in trying to repair the vacuum.
  • fixerwantabe Mar 31, 2008
    I am a do it your self repair guy most of the time I am able to fix what ever it is ,I have had real good success rate .I am not afraid to ask what would seem to be the goofy/dumb questions. I have learned allot over the years fixing my own break downs. During a home construction clean up allot of drywall dust happened to get all in the motor of my BISSEL UP RIGHT VACUUM.After taking out the12 amp motor to blow out all of the junk I attempted to pull off the the aluminum fan with out proper tools to get full access and I managed to bend a fan fin causing it to get out of balance I found a replacement after I put it altogether now it appears I have a weed blower NOW ! some where I crossed some wirers How can I get the motor to turn in the other direction ? Thanx TIM ALLEN, LOL
I saw this kind of vacuum on a sidewalk, someone didn't want it anymore. I checked it out and it wasn't sucking from the motor brush. I check the small hose at the lower rear of the unit and it was totally clog. I cleaned it well and it was working again. Poor vacuum it just needed a little TLC. But I discovered when the dust bag cover isn't close correctly (or if theres any leak ) there will be no sucktion what so ever. Make sure that the vacuum bag cover is sitted well...hope this help.
Posted on Oct 07, 2008
How do you get to the motor on ta tank tyoe eureka model 3935.
Posted on Aug 24, 2008
On my vacuum the "vacuum fan" (my name for the part which creats the suction) broke off the motor shaft. The vacuum sounded like it was working, but there was no suction. If you are sure there are no clogs (drop a marble down any hoses you can't see through), then this is the likely cause.
Posted on Oct 12, 2007
Eureka optima 431 brush motor works but suction motor doesn't
Hi Patricia, it's Jack at Dyson.
It doesn't look like your question is about a Dyson vacuum. You might like to resubmit it under the correct category to be sure of some helpful advice.
Feb 06, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Eureka 5902AVZ and the brushroll does not work. when i remove the belt, which is not torn nor worn out, the motor spins perfectly fine. Though when i put the brushroll back into place, it shows...
Hi and welcome to Fixya. I am Kelly.
You have correctly identified the problem as the brush roll itself.
There is a bearing under each end cap of the brush roll. You can gain access to the bearings usually by gripping the browah roll end caps and rotate the caps in opposing but loosening (ccw rt / cw left) directions.
Many times I have found that there is just a mass of hair under the end cap that functions like a brake. Clean it up really well on under BOTH end caps.
Do a spin test by putting the end caps back on (Hold it horizontal) and rotating the brush roll with your thumbs. It should spin freely.
If it feels like there is still friction then your probably going to have to take the brush roll with you down to the nearest vacuum cleaner repair / supply shop and get 2 new bearings. Most shops will install the NEW bearings for you if you have the brush roll in hand. It is a much cheaper fix than the brush roll itself.
(buy a new belt too!)
Take care
Kelly
http://www.eureka.com/servlet/ListParts?model=5902avz
Feb 10, 2010 | Eureka 5902AVZ Bagless Upright Vacuum
Eureka rm 4480
Hi there SmartAlec from NelsonVacuums.com.au . Unless there is a bad sound coming from your vacuum i would suggest you have a blockage. This machine is prone to getting blockages in 3 different places.
  1. at the base behind the brush.
  2. Inside the main suction hose - this should be removeable so you can drop a small coin through. If it doesnt fall easily viola blockage found.
  3. Where the dirt enteras the chamber or bag.
Basically start by removing all hoses and filters and turn machine on put your hand over all inlet and exit points provided you can feel airflow at one of these points work backwards from there and identify the point at which you no longer feel airflow.
HAPPY vacuuming !
Aug 26, 2009 | Eureka Whirlwind 4480 Upright Vacuum
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
I have the Eureka Whirlwind upright vacuum. All of a sudden there is no suction- the hose has suction but not main part. I have no idea- but the brush part is not turning??? should I get a new vacuum or...
If the belt isn't turning then it has snapped. Check the top of the hood for two or three crosshead screws; two at the front and one under neath by the left hand side if looking at the upright from the front. Its easy to fix if you take your time and you have a spare drive belt. Check EBAY in your country for spares.
After you put a new belt on make sure the roller beater is completely free of threads as this will keep the belt longer for running.
Jun 18, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Have eureka 9734 replaced belt, put back together,brush rotates well but vacuum is not picking up anything, no suction.
It sounds like the machine is clogged. Check the port behind the belt and any and all hoses for obstructions and remove.
Apr 13, 2009 | Vacuums
Eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Oct 03, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka vacuum
if you have ran over any big objects you might try removing the cover from bottom take out the roller brush and see if it is clogged from the bottom
Nov 30, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
1,909 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
