Question about Marantz Audio Players & Recorders
Set wouldnt turn on no sound or lights
set was playing and just cut out ,no lights or sound.
    Brigadier General:
  • 8,619 Answers
Hi
Often the cause is blown output transistors. This will often burn up biasing resistors and some of the small driver transistors. You can check it directly by the main amp; follow the leads from the speaker terminals and you should find something on a heat sink. If there are two transistors see if they are running hotter than the other channel. If you see any damage to them (compare with good channel) replace both. If all you see is a black box with pins coming out of it you need to replace that. They sometimes have the letters STK on them. Replace both types with the letters and numbers of the same type.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 11, 2009
When i have recorded something and play it back the recording is phasing
My first thought is your play back volume is too high and your file choice is wrong. While your playing back your recording, press the down arrows on the ring of buttons on the front of the recorder. The top and bottom button turn down the playback, the right and left buttons turn down the "recording" input sound. Set your file area setting to "all files". Better yet set your recorder to these settings it will work well for most recordings. I got this on a 3x5 card and check to make sure I got these setting before every recording.
1. Input "on" 2. Recorder onboard speaker "off" when recording. ( not a big deal I just do it) 3. "low cut" set to 80 ( this will help filtering house background like your AC unit sounds from lights and if out side some sounds from the open air ) example; 124hz is the note B. So we don't want cut that out. So 80 is good for indoors haven't used it outside yet. This next setting is key for phasing and squalls and recording at all and that number 4. 4. Setting "Area" to "All Files". ( Not sure what all files does but it started working after I changed that to All Files so I don't care why just do it.)
Once you get these settings right all you need to do is make sure input is "on", and watch the peak light which is left of the record light. Make sure the peak light doesn't come on very often, turn down your input volume just a tad if it is, just under that is perfect. I always got to think of this to and that is make sure when you playback you must "turn off" ..."In put". That input on or off and and input volume is what I am always thinking about when working with this recorder. I have had this recorder right in the middle of us with a drummer, bass, two sometimes three guitars and a conga player. All playing in a circle. I set the recorder right in the middle of us on a camera try pod about 4 feet high and the recording are great. Just watch the peak light and it will do surprisingly well. I love it and the band is impressed. I sometime put it front of us when we play in a stage straight line but the drummer is not heard as well. So stick it right where you are and watch the peak light so it won't come on. enjoy, I am. patbham
Jan 11, 2013 | Tascam DR-05 Portable Digital Recorder
I just went outside to crank my car to leave but when i turned the ignition over my car wouldnt start. The lights,radio and everything else is working fine except for some crazy things that popped up on my...
It sounds like the car is still in gear make sure it is set all the way to park, this will give you the same problems. If this does not help repost.
Mar 30, 2011 | 1999 Pontiac Grand Prix
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
F1 light comes on bike cuts off of my 2008 gsx . i change oil -gas- and bought it to the shop and the same problem. when i turn the bike on i runs for a little while then turns off
F-I is fuel injection system telling you to clean air-filter,fuel-filter and clean the fuel injector system. This is a good start.
Apr 11, 2010 | 2007 Suzuki GSX-R 750
Rca P52927 TV will not power up and chirps when plugged in. Any help?
while playing ps3 on the tv first a chirping sound, then a loud pop then the set cut off. After the set cut off the red timer light stays on.
Jan 23, 2010 | RCA Televison & Video
I left work it was running istopped at the light and it wouldnt take off when thelight turned green just ribbin up
SOUNDS like a Auto Matic transmittion band or pump playing up so its in the box so check the automatic trans fluid and hoses to radiator whitch keeps it cool...
Let me know how you go Ron
Oct 15, 2009 | 1990 Cadillac Deville
Motorcycle want turn over
your battery is not getting charged, charging system needs to get checked. there may be a short causing this, check the bike for any loose wires
Sep 02, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Fuel gauge going up and down and car wont start
Sounds like a bad fuel sensor or bad connections both are in the tank
Jan 26, 2009 | GMC Blazer Cars & Trucks
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Sound cuts out
If you listen to cd's and the sound dos'ent cut out then it cant be the amp. It could be the audio cables are intermittant between the amp and the dvd playerr or they are loose or corroded a little. or ppossible the input your using is going bad on the stereo sytem but I wouldnt think that the whole system was blown if the radio and the cd plays normal.. check out the causes I listed and let us know if you need more assistance\..:)
Apr 19, 2006 | Technics SCEH790 CD Shelf System
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
