Question about Pioneer DVL-700
Tray Not Open
I just bought this LD and when I push the eject button in the screen appear "open" but nothing happen. Sounds like if the tray is blocked. Have this unit a block mechanism or something like that?
  • Sergio Ormeno Oct 13, 2007
    Thanks for the answer. Unfortunately, the unit is not new. It was bought used, but I saw it working. When the unit arrives to my home the tray not open. And the suggested solution not worked.
    I remember to have read in Internet that, to transport this unit, was a retention screw that had to be fixed. Do you know if really there is a retention screw in this unit?
    Many thanks for your help.
  • Sergio Ormeno Oct 16, 2007
    Due a defective transport, the laser header is "flying" in its guide. That's the problem. If you "shake" the unit the laser header is aligned and then when you press eject the tray open. I will take the unit to the technical service.
  • 661 Answers
Possibly what hass happened is that your disk has got wedged, (or that someone tried to insert more than 1 disk)
try GENTLY shaking the unit (unplugged) to see if the disk mechanism frees itself.
as it is NEW you really shouldn't do any more than this as it would invalidate the warranty, take it back to the shop you got it from and they should handle it for you,    Tell them not to forget that you have a disk in the drive.
Posted on Oct 12, 2007
I have a dvd stuck in the slot. It won't play or eject. I hear the tv trying to eject but nothing happens. How can I fix it?
You will need to open up both dvd case and dvd player! the rubber type band that turns the wheels to open tray is bad, not tight enough to turn wheels! This rubber type band is located at the front of tray. you might be able to get tray to open by taping the top front of player after you push eject, just not hard enough to bend case.
Mar 25, 2016 | Televison & Video
Cd tray eject button doesn t work - paper clip trick doesn't help
the "paper clip trick" isn't a trick. It is a MANUAL way to open the door far enough to pull it open and remove the contents. Straighten out the clip. Place it through the tiny hole just above the eject button. Be sure to push it straight in. When you feel resistance, push HARD. the door should open about a halt inch and allow you pull it all the open. It will not open automatically from a paper clip.
Dec 11, 2013 | Acer Aspire Computers & Internet
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
I went to put a game in the xbox to play,I waited for it to load & nothing happened.The screen said open tray.I waited & waited but nothing.I pressed the green button on the controller but the tray...
Well you may be having disk tray issues, sure hope so as compared to a burnt out lens module,try ejecting the tray fully and wiping all dust off around the grooves under the tray,one more tip is to keep a disk in the drive at all times, even when you aint playing it, you can also try giving it a gentle tap on the front pat where the disk tray is located any time you eject it or push the tray back in, come to think about it if you are fond of pushing the tray in after inserting a disc, stop cos it weakens the motor that drives the ejecting process, hope this helps...
Oct 25, 2010 | Microsoft Xbox 360 Console
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
Stuck dvd tray
There are many ways to eject a DVD. Try this.
Shut down the computer (complete power off, not restart)
Hold down the left button (Apple mouse?)
Push the power button
Keep holding the mouse button down until it either ejects or the grey pinwheel appears. (It's not an instant process)
Usually, eject/F12 will open the drive up. If that does not work try.
Open terminal and use the command "drutil tray eject"
You can also try command-option O + F and type"eject cd"
If none of this works your drive may be bad or the power cord is loose. You will need to open it up or seek professional service.
Oct 08, 2009 | Apple Power Mac G5 Desktop
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
Dvd tray stuck
The is a small hole next to the tray
Find a paper clip and gently puch the release the tray should open
LB
Sep 14, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Pioneer DVL-700 Logo
187 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
