No wireless connection
NO WIRELESS NETWORK FOUND MESSAGE WHEN OTHER IDENTICAL COMPUTERS HAVE AT SAME LOCATION, WIRELESS IS TURNED ON. THIS IS ON A PANASONIC CF-30 TOUGHBOOK. HOW DO I REPLACE THE WIRELESS CARD
  • Anonymous May 11, 2009
    i have a panasonic toughbook running windows that i am using at this moment and i have two others like this one, that i need to combine and make one that operates correctly, i need to know where the wireless card is in and put it in the other.
  • 32,281 Answers
What do you mean by other identical computers have the same location?
Each wireless card has a unique MAC address so they should not interfere with each other. Are the laptops all communicating with the same wireless router or different routers?
If the laptops are communicating with different routers and there is interference between then you should change your wireless router to work on a different channel to the other routers.
Posted on May 11, 2009
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Tip
Wireless Network issues. Validating identity and Certificate Errors in Windows...
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:<br /><br /> <ul> <li>"Windows was unable to find a certificate to log you on to the network." </li> <li>"Validating identity" replacing the name of the wireless network. </li> <li>A pop-up window requesting for login credentials off the wireless connection. </li></ul><br />To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers. <br /><br /><span>Manually add a wireless network on a Windows Vista computer:</span><br /><br /> <ol> <li>Click Start, and then select Network. </li> <li>Select Network and Sharing Center.</li> <li>Click Manage wireless networks.</li> <li>Click Add and select Manually create a network profile.</li> <li>Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field. </li> <li>Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes. </li> <li>Click Next and close the window.</li> <li>Go to the Network and Sharing Center and select Manage network connections.</li> <li>Right click on Wireless network connection and then select Status. </li> <li>Click details and check the IPv4 address. </li> <li>If there is a valid IPv4 address, check if the computer can access the Internet wireless.</li></ol><br /><span>Manually add a wireless network on a Windows XP computer </span><br /><br />Note: The following steps are for a wireless network that has WEP security.<br /><br /> <ol> <li>Click Start, then select Control Panel.</li> <li>In the left pane, select Switch to Classic view.</li> <li>Click Network Connections.</li> <li>Right click Wireless Network Connections and select Properties.</li> <li>Click on the Wireless Networks tab.</li> <li>Click the Add button.</li> <li>Enter the name of the wireless network (SSID). </li> <li>Set the encryption type to WEP.</li> <li>Clear the key is provided for me automatically check box.</li> <li>Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.<br /></li> <li>Right-click Wireless Network Connections and select Status. </li> <li>Click on the Support tab and check if there is a valid IP address.</li> <li>Check if the computer can access the Internet wirelessly.</li></ol> <br /><br />If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.<br /><br /><span>To disable IEEE 802.1x authentication: </span><br /><br /> <ol> <li>Click Start, then select Run.</li> <li>In the Run dialog box type ncpa.cpl and then click OK.</li> <li>Right-click the Wireless network connections icon, and then select Properties. </li> <li>Click the Wireless network tab.</li> <li>Click the Properties button beside Remove. </li> <li>Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.</li> <li>Click OK to update the settings.</li></ol>This TIP applies to: <br /><br /><span>All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).</span>
on Apr 28, 2011 | Computers & Internet
I am trying to connect to the web with my new sylvania ce netbook and it has the right password in it I click the internet icon says connecting the shows up unable to connect. Can you help me or should I...
Using the Personal computer to arrive into network requires turning on the device that would have a password to display the system windows. After the computer turns on though would have required a computer user password or possibly not, locate an internet explorer icon whether example; google, mossilla fox pro, chrome, netscape, internet explorer, are just network interface where network features would show up on. 2. clicking on the internet icon should require a password if built to require user pass before joining a network. 3. The password would possibly been disabled in some instances, where for example clicking on the internet explorer icon should simply display a page welocoming the network required. For example, if the internet explorer icon is clicked showing display page momentarily, then www.Google.com is typed in the search space of the page displayed, a connected network should show another page displaying the features of the page or site google show mometarily after search space has been click. An unconnected network would always display a message or network unavailable or internet not setup and requiring establsiment. The most situation would be a message communicating the cause of network malfunction. if the computer has a network subscription plan, for example a provider that has promised to network the computer in question for fees, where would have provided the computer user an installation kit either software to install on the computer to be linked to a network. The computer with networking defaults would turn on completely only after which just cannot network into another setup when a page is clicked onto it. Simply, ask your network provider for further assistance.
The following are network providers to contact for subscription and technicallities involving computer telecommuncation.
Cricket wireless services
AT & T wireless services
T-Mobile wireless services
Verizone wireless services
Pocket commication services
Trac wireless services
Boost mobile wireless services
Visit any locations to inquire about networking functionalities to phones or computers or contacting online by email or phone with questions of connectivity
Dec 04, 2010 | Computers & Internet
I just set up a new WRT160N wireless router. The PC connected to it works fine. My son can not connect to the wireless connection, even when he is 10 feet from the router. The response is " Unable to...
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
Jan 02, 2010 | Linksys WRT160N Wireless Router
How do i turn on the wireless function on my router
For Windows XP -
For MAC OS
Dec 22, 2009 | 2wire 2700HG-B Router (2700HGB)
How do you set up the wireless
For Windows XP -
For MAC OS
Dec 19, 2009 | NetGear WGR614 54Mbps Wireless Router...
The netgear works when plug it to netgear to compter bt by wireless it dose not work what do i do
For Windows XP -
For MAC OS
Dec 13, 2009 | NetGear WGR614 Wireless Router
Wireless connection for Win 7
For Windows XP -
For MAC OS
Nov 25, 2009 | NetGear DG834G Router
Everytime I try to connect using the WUSB54GSC it
You need to Update the Drivers for your Wireless Adapter...Download the Drivers from here
After downloading the drivers you need to unzip the file...After you unzip the file you should un-install the adapter drivers/software from Programs menu...Leave the adapter connected to the PC and reboot your computer...Once the computer is rebooted you should see a message "Found new Hardware"...Select the option Install it from a specific location and click Next, then select Include this location in Search and browse to the place where you have unzipped all the files and select the Driver folder and click O.k...Then click Next and it should install the adapter drivers...
NOTE : This installation doesn't install the software(Linksys Monitor)...
Once the Adapter is installed, Click on the Start button >>> Control Panel >>> Network Connections- Right click on the "Wireless Network Connection" icon and select "View Available Wireless Networks"- If you see your wireless network in the list, highlight it by 'single' clicking on it- Now click on the 'Connect' button below- If your wireless network is secured, it would ask you to provide the network key- Provide the wireless network key and confirm it again in the confirmation box and click "Connect"...It should connect to your Network and Internet...
Jun 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Acer Aspire 6930 wireless on off switch
The wireless card has dropped the IP address, to get the wireless router to issue the wireless card with a new IP address, right click on the wireless connection (the one with the red X) and left click on Repair.
When the red X disappears then you can connect to the Internet.
Apr 13, 2009 | Acer Aspire 6930-6771 Laptop
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
