Question about HP (228513001) Fan Kit
Dell Desktop (Optiplex 745) couldn't run
I have following problems:
1) When I press power button. It shows indicators blinking.
2) But the cooling fan doesn't runs as well as there is noting displaying in monitor ? What could be the problem.
    President:
  • 814 Answers
This could be a bad power supply. When turned on do you hear any fan noise from the power supply. If not check and see if the power supply looks dirty of has a burnt smell. This could indicate a bad power supply.If the power supply is working, check all the connections to the motherboard for possible loose connections.This would cause a failure of the power good signal to allow the computer to turn itself on.When checking the connections check the motherboard for dust and dirt that may be affecting the operation of the cooling fan. Check the fan itself and check the motherboard for possible bad capacitors. These can be identify by bulging tops or bottoms. Check the main processor for the same dirt and dust problems and check to see if the heatsink is making good contact with the processor to cool it correctly.You may have to remove the heatsink and reapply thermal paste and reseat the heatsink itself to insure proper operation. You must also check the memory of the computer to see if it is seated properly and is functioning.You must use antistatic protection to check this out by ground yourself on some nonpainted metal object to discharge the body static. If you do not do this you could damage the memory and the processor if you must touch and remove them for cleaning. You should use canned air to blow all the dust and dirt off the motherboard and connectors.be sure to never due any cleaning or troubling shooting on your computer with the power connected. You amy also try to isolate a bad component in you set up by disconnecting all items in your system but 1 stick of memory and harddrive. Leaving all other components disconnected to see if the computer will start. Then connect each component back including the memory sticks to see if you get a failure again. the last component you attach before the failure will be the faulty one.If non of the above solutions help you may have had a motherboard failure and may have to replace it. Hope this helps you with your problem. P.S. if this is over your head then take your unit in to a service center and have them check it out for you.
Posted on May 12, 2009
I have a dell optiplex 745 and the light on the power button flashes orange when power is connected. There is also no notable damage to any capasitors on the motherboard.
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
May 08, 2012 | Dell OPTIPLEX 745 PC Desktop
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Dell mini computer power button blinks orange whats the cause?
A blicking power light and no boot indicates one of two things. First, an error on the motherboard caused by failed capacitors or two a power supply that is not putting out all of the correct voltages. To check the motherboard look over this article:
http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/
If you don't see any bad capacitors then the power supply will need to be changed.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 29, 2011 | Dell OPTIPLEX 745 PC Desktop
My Dell Optiplex 745 Desktop PC Power light orange blinking how can i solved it..
The orange blinking on your desktop power button says that there's a problem with either the power supply or the motherboard itself.
Please refer to this link for the diagnostic lights on dell computers.
What you can do is: 1. unplug the power cord 2. press the power button, hold on it for more than 5 secs 3. re-plug the power cord on your CPU 4. test if it the system will work.
If this troubleshooting step does not help, that means it is more likely that the problem is with the motherboard.
Hope this helps!
Sep 14, 2011 | Dell OptiPlex GX270 PC Desktop
When I start Dell Optiplex 330 only the orange ligt of the start button blinks and nothing else is working. I tried removing the memory (RAM) clean and replace still it is the same.
This is usually an indication of a failed motherboard. This is similar to the Dell 745 at my work, that had the same problem. After running all of the normal tests, I found the problem to be the motherboard.
Oct 09, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I powered off my Dell Optiplex 745 as normal one night before bed. The next morning I went to turn it on and it just displayed a yellow flashing light where it normally displays a green light. The fan did...
This model has been having problems with the motherboard that can cause that exact problem, Not powering up, Flashing yellow light or locking up right after booting up. The first thing to check is parts called capacitors on the motherboard. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/ that has detailed pictures and information about this issue. The pictures are of the tower case Optilpex 745 but the board is the same for your unit. Check it out and see if your board has this issue. If you can solder then you should be able to fix it yourself for less than $15.00 If your board does not have the bad capacitors then the blinking yellow light is a failure in the power supply unit.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 28, 2010 | Dell OPTIPLEX 745 PC Desktop
My computer is blinking orange light
In addition to the power supply, motherboard issues can cause the blinking power light and no boot problems. The Optiplex 270, 520, 620, 745 and 755 units are all known to have issues with capacitors on the motherboard. Here is a link to an article about this issue and what to do about it:
I hope this helps, if sol please rate my solution.
BuddyMc
Aug 10, 2010 | Dell OptiPlex 360 Desktop Computer
Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Apr 24, 2009 | Dell OptiPlex GX620 PC Desktop
Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
HP (228513001) Fan Kit Logo
962 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
