Question about Garden
I need a manual for a weedeater pe550 edger. - Garden
  • 246 Answers
Hello:
You can Download Manuals After doing a Search Using your Units Model Numbers at this Site Addy; http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
or you can Contact Poulan/Weed Eater Using the Options at this Site Addy; http://www.poulanpro.com/poulanpro/contactUs.do .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Which of the 2 fuel lines on PE550 edger is the steady fuel line for constant running?
Trace the hoses down into the fuel tank, the one with the fuel filter on the end is the main fuel line.
Aug 10, 2013 | Poulan Pe550 Gas Edger
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
The screws that hold the carburetor vibrated out and are lost. Any idea what size they are ? SAE or metric ?
Here is your part. To see your whole machine, just select Weedeater PE550 and a couple parts diagrams come up. The part number with a photo and the price are here as well. Shipping is stiff, but this is the best I can come up with. The head is TORX 20 it looks like (could be T-15), but the thread style is the important thing. Good luck!
http://www.ereplacementparts.com/carb-screw-p-269854.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
How do i tell what type my model pe550 is
its usually part of the serial number tag
Sep 24, 2009 | Poulan Pe550 Gas Edger
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Poulan pe550 edger problem
Did you adjust the carburetur screws?
Sep 12, 2008 | Poulan Pe550 Gas Edger
Garden Logo
5,082 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
