Remote Desktop Hi, can you tell me how can i login to another computer by using broadband internet. I want to do Remote Support, VPN, File Shaing and chatting with my client Thanks a lot
  • 31 Answers
Yes, you can do all you want by using TeamViewer. A special software program from  www.teamviewer.com  just go to the above URL and download the software and select personal/non-commercial use when you intall the software.
Best Regards
Krishan
Posted on May 11, 2009
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
  1. Open Remote Desktop Connection
  2. Select the connection you wish to use with both displays
  3. Right-click and choose Edit
  4. Check the "Use all monitors" box at the bottom
Thanks
Aug 01, 2012 | Apple 24" iMac Desktop
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
HN9000 won't pass remote services
On the Router check if you have UPnP enabled, if yes then Disabel it that should fix the NAT issue and then you need to open the port number 1723,3389. Once these ports are opened then you will be able to access it on the VPN and Remote Desktop Provided you have a WAN IP Address from your ISP. also check the Firmware of the router if its updated or not.
Mar 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a Belkin N1 wireless router connected to a broadband cable modem. I can connect to the internet via laptop & desktop with no issues. However when I try to connect to my work Sonicwall VPN it...
Firewall ports need to be opened. Log into router and turn on DMZ to your computer. Find your IP address on your machine 192.168.X.X and put that into DMZ settings or open up appropriate ports for VPN
Feb 11, 2010 | Belkin N1 Vision Wireless Router
My employer gave me a Dell 6400 Latitude Laptop to use at home through a VPN connection. I have a plug in connection at home. How do I hook up my laptop at home?
Connect your ethernet cable from your Broadband modem into your laptop. Make sure you can browse webpages. Open the VPN software installed by your employer, and enter your login credentials assigned by your employer to authenicate. Once connected, you will have Network Access and Intranet Connections to your workplace. This will work from WiFi hotspots, hotels, Internet cafes, etc. If you do not yet have your VPN software installed, or have your credentials, speak to your employer as they may need to create and account and a certificate for your VPN connection.
Nov 10, 2009 | Dell Inspiron 6400 Notebook
Cannot load and login facebook
Hi: here is what to do :
- VPN
A VPN lets you access Facebook from a normal internet connection. It’s a little bit of software that you install on your computer and then run after you connect to the internet. It sends all of your internet information through a different computer (located in the US or UK for example)… Try www.witopia.net for more information!
- Proxy
A less elegant option, but just as useful, is to use a web based proxy. There are many of these available, one of the best is ’sneak me’ (www.sneakme.net). You input the web address that you want to access and then click on ‘OK’ and you can go straight to the site you need.
- Business firewall bandwidth
Some businesses buy bandwidth directly from Chinese telecommunications companies, so multinationals for example can have full access to the Internet without any interruption.
Good luck
Jul 10, 2009 | Facebook Social Network
I have VPN connection, but it is not connecting in to VPN, but connecting broadband only. please help me how to configure VPN network from Broadband. Total Treasury department in Srikakulam District using...
there might be some problems and you have to go through them.
--> check the cable
--> check the vpn connection settings
--> check the server name
--> check the user name and password (it should be same as of your system in office
--> make sure your computer is on at work
i hope this will help you
if none of them work then the easy way is to make other connection that will definitly do
Mar 24, 2009 | Sony VAIO FX150K Notebook
Can tlog in sg300 using a satellite remote access
Accessing a VPN through a BGAN should be fairly simple. It sounds like some of the settings for the VPN might have changed. If you changed any settings on your computer, or if you have added any type of security settings or firewall. If you need any assistance with your BGAN let us know. We do sales of Satellite internet terminals such as Thrane & Thrane, Wideye Sabre, Hughes, Fleet Broadband, and much more. We also do repair of Broadband satellite terminals. You can visit our website at www.BlueCosmo.com, or call us at 877-258-3496.bcrepairs.png
Dec 31, 2008 | Secure Computing SnapGear SG300...
VPN?
A VPN is a Virtual Private Network. It is used to protect you from getting caught downloading pirated movies and software. It is an Encrypted link with a 256 bit AES seed key which is impossible to decode. Not even your internet service provider can tell what is going in and out of your computer. It costs about 25 dollars a month for a secure server in Amsterdam to be the safest. Every 1 and 0 is totally scrambled and sent to the server in Amsterdam, the downloading of the movies and such takes place there. Then the data is scrambled again and sent back to your computer and once it is safe at home it is then descrambled. Wih one of these VPN bad boys you do not have to worry about those RIAA people sending you threat letters telling you to stop downloading their movies and other copywritted materials. The server in Amsterdam only keeps the logs for three days and it takes 7 months to get a warrant there. If you wish to learn more about these VPNs and how to get everything for free feel free to get in touch with me and I will set you up with the coolest company in the business. These days you can't do anything fun or worth while on the internet without a VPN. For more info contact: geokohler@gmail.com and put VPN in the topic. Thanks for reading about VPN's now go out and get yourself one before youget sued by RIAA.
Aug 02, 2008 | Linksys Wireless-G Broadband Router
D-Link Vpn Router model DI-804HV
Can you tell me the setup with your router? It should be Internet->Modem->Router->Computer If that's setup properly (the wires in the right spots) then go to the gateway IP of the router...it might be something like "192.168.0.100 "so you put that in your internet browser. The default user is "admin" with no password. Make sure to run the "Wizard" while on that page and after that go to the "Status" page and check to see if the WAN connection is connected properly.
Aug 28, 2007 | D-Link DI-804HV - 4-Port Broadband VPN...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
