Question about Carrier BCA101R Air Conditioner
What does the ION button on the remote mean and what is it for?
    Scholar:
  • 152 Answers
The ionizer positively or negatively charges the air as it leaves the fan coils and kills bacteria which is airborne good for people that suffer from alleges
Posted on May 11, 2009
Saturn ion trunk release
have you checked the fuses for these things -cheers Denny
Nov 01, 2013 | Cars & Trucks
My 2003 Saturn Ion remote trunk release won't
Check to make sure the button on the trunk latch is turned from manual unlock...they made that feature so only the key will work to open the trunk that way if someone breaks in the front of your car they can't hit the trunk release and get into the trunk...may be the same thing for your remote. Hope that helps.
Jun 13, 2011 | 2003 Saturn ION
How do you lock a saturn 2007 ion car's door with a key?
Put the key into the keyhole and turn it counter clockwise. Now, if you want to lock all doors without using the key or the remote key fob, you can press the lock button your door. The car will chime a few times, then shut your door. About 5 seconds later, all doors will lock. Neat, huh?
Nov 01, 2009 | 2007 Saturn ION-2 Quad Coupe
06 Saturn Ion, starter disengages
the car with a padlock symbol means security system,,,you either have a bad ignition switch causing this issue and or a passlock housing,,,sounds like a normal problem,,,when the ignition switch/passlock housing goes bad it can work sometimes and not others,but it will cuase the car not to start,, i bet there are codes stored in the computer,,you are gonna need to take it to the dealer,,
Oct 07, 2009 | 2006 Saturn ION
2006 saturn ion door locks and trunk pop wont work....
The remote won't ework because the problem is in the vehicle. Just for test purposes and possible remedy. Remove and clean the negative battery cable. Ensure a clean , tight connection. Then find the body ground. Yhis ground is locted usually at the top rear of the engine. .I's a snall stainless steel strap bolted to the engine and fire wall, This must olsobe clean with a good contack. Might as well clean the + cable and connection on the battery while you are there. Good luck and keep me posted olease. Good Luck, Ned_
Oct 03, 2009 | 2006 Saturn ION
How do i fix the remote start on 2005 saturn ion the remote works but nothing happens
Check the remote start fuse that is in the fuse box under the hood.
Sep 12, 2009 | 2005 Saturn ION
2003 Saturn ION 2 trunk Problem
there is a manual switch that is located near the trunk latch for a safty lockout it might have been switched by accident look to make sure.hope this helps.
Jun 21, 2009 | 2003 Saturn ION
Remote for Pioneer HTV-2 not working
I never did fix the remote, but I was able to use my other remote (universal) to control the Pioneer HTV-2. Thanks
Jun 04, 2009 | Pioneer HTV-2 System
Switch on car
Lots of Issues with Ignition switches. Car will not crank due to incorrect pass lock voltage to BCM.Most Likely Has A DTC B2960,B3033 Stored in BCM Most likely need another Ignition switch..Good Luck
May 03, 2009 | 2004 Saturn ION
Carrier BCA101R Air Conditioner Logo
2,550 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
