Back to:
Tags:
Canon PIXMA MP150 All-In-One InkJet Printer
Waste ink full (by 3 users)
posted by mrmessy41 on Oct 12, 2007
the waste ink reservoir is full how do I deal with it?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ConanSucks, posted on Apr 17, 2008
I called Canon and they ant me to buy a new printer!! How can I do this myself?
Comment by Guest, posted on Apr 14, 2008
he waste ink absorber is full.
Contact the service center for the replacement of the waste ink absorber.
The remaining level of the following ink is unknown.
Color [24]
The following ink tanks are running low.
Black [24]
There is a possibility that the printer cannot detect the remaining ink level properly. Reset the ink counter using the Maintenance tab of the printer driver whenever you have replaced any ink tank with new one.
Best Solution
posted on Oct 23, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Worked a treat.
Thanks!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on waste ink full:
I don't want to Accept this solution
Solution #2
posted on Feb 24, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
How about a description for people who need to know which buttons to press in what order... your solution here is all do this... but first do that and while you were doing that do this first- freakin impenetrable.......
Thank You!
Solution #3
posted on Oct 12, 2007
Helpful (85)
Vish2
Rank:Guru Guru
Rating: 88%, 183 votes
Following is the procedure to reset the waste ink counter for the Canon Pixma MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Thank You!
Can you Help with these Printers problems?
Hi I have a Canon Pixma MP 150 purchased in Aug 2006. I...
After installing new cartridges for color and black ink I...
Dear Sir, I have some problem with may canon MP150. The...
g changer de cartouche et depuis tous les boutons...
I just bought a new Canon MP145 "All in One",...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
