Question about Pioneer VSX-D811S Receiver
When putting master volume on 30 the receiver puts overload and shuts down i have installatin of 6 speakers and all worked well since 4 years already and i used to go over 20 in volume this problem occured yesterday and nothing was modified in my installation thank you for your help
  • 979 Answers
SOURCE: overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Posted on Nov 26, 2007
SOURCE: Pioneer receiver shuts off
This might not be any help to someone else, but I fixed the problem by double checking all the speaker wire connections - on the speakers and behind the receiver. A couple banana plugs felt loose and I discovered that one connection on one speaker was out completely. Suppose I should have seen that sooner, but as soon as I ensured all the wires were where they were supposed to be, I encountered no more problems.
If your Pioneer receiver is shutting off on you, double check all your connections!
Posted on Jun 20, 2009
ginko
  • 19396 Answers
SOURCE: VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Posted on Jun 22, 2009
  • 4 Answers
SOURCE: THE SPEAKERS FRONT LEFT AND RIGHT IS NOT WORKING ON DTS and 5.1
Do you have the manual if not go here.
http://www.hammerwall.com/Manuals/Pioneer/Description/VSX-D608/Pioneer%20Home%20AV%20Receiver/L0020200/
Posted on Aug 21, 2009
  • 11 Answers
SOURCE: Receiver shuts down when setting volume above certain range.
What ohm speakers are you using? this receiver doesnt work very well with speakers that have an ohm rating below 6
Posted on May 17, 2010
I have Wharfdale 4000 Xarus speakers connected to my Pioneer VSX 817, the last 6 months it keeps saying overload when i have the volume further than 40db. Never use to do it... and i have re wired the...
Testing your amp at max with the speakers disconnected will not play a factor because there is no power being drawn so the amp is not being used. Those speakers are rated 90db and really pound but also draw a ton of amps. The key thing here is to keep it cool, cool, cool. Put a fan on it and keep your receiver on a hard surface with nothing stacked on top or anywhere within a foot of it. Keeping it cool will help prevent overloads or (protection mode). Back it down every now and them and give the system a rest for a few minutes. Double check the negative and positive connection on the speakers to the receiver. We all have hooked them up backwards sometime and this will have the effect you are expressing. What is the phase set at on your receiver? Set it down to "0" and go up to where it sounds best without distortion. One more very important thing. What is the Ohm switch on your receiver set at? Put the switch on 8 Ohm even though your running 6 Ohm speakers. That switch only steps down your voltage feed to the power selections which will hamper the overall dynamics and fidelity of your receiver. This switch is really not even necessary. Putting that switch at 8 Ohms will give you more headway and aid in keeping your amp cool.
Regards, Tony
Mar 24, 2011 | Pioneer VSX-817-S
Receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Mar 30, 2010 | Audio Players & Recorders
disconnect all your speakers and if it still does it, yes, take it to service. if not, check all your speakers and wires. good luck
Feb 09, 2010 | Pioneer VSX-815-K Receiver
We have had a Technics stereo for 16 years and have had NO problems until the last couple weeks. If the volume gets turned up, the signal will come on that tells us that there is an OVERLOAD. We have tried...
Disconnect the speaker wires at the receiver, turn up the volume, if it goes into protection, it's an internal problem and needs service. If it does not go into protection, re connect one speaker at a time and test. If it shuts down check the speaker itself, if they are as old as the receiver, chances are good that the surrounds on the speakers themselves have disintegrated. Older speakers used foam surrounds, newer ones use rubber or plastic composite material that will not disintegrate. What will happen is dust and moisture will get into the voice coil and cause a short, even though the speaker still plays. Hope this helps. If you need more help or just advice, post a comment, and I'll help if I can
Jun 28, 2009 | Technics SA-EX320 Receiver
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Apr 21, 2009 | Marantz SR-5200 Receiver
I Have a VSX-917V-k When I put up the volume past 25 it works for a minute or two and then its says overload and shuts off. The speakers are older than the system but they r 15" Technics which work at 8...
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. I could guide you a bit. If not, then a local service center will change the local labor rate. Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further. Thanks for using FixYa!
Mar 09, 2009 | Pioneer VSX-917V-K Receiver
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Onkyo 705 receiver shuts off at higher volumes
I had this same problem and it turned out to be a twisted kink in the speaker wire. Run a sound check to each speaker separately (from your receiver menu) and turn each one up until the receiver shuts off. Check the wire to the speaker that caused it to shut off and make sure the +- ends are not touching each other at either end, and that there are no twists or kinks along the way.
Nov 04, 2007 | Audio Players & Recorders
Overload
Firstly check all your speaker wiring. Any damage can cause a short which will overload the system. You might not notice it, due to the fact that when you have the system on loud, vibrations move the wires on the cabinets or elsewhere. So make certain there are no loose wires near the speakers terminals into each one. If all that is good go to the next check.
Check If the amp is getting VERY hot when the overload occurs, then it might have a faulty part(s) on it. This might have occurred if you have been using speakers that never did match the amps requirements in the first place.
Mar 12, 2017 | JVC RX-668V Receiver
Pioneer VSX-D811S Receiver Logo
123 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
