Css code for system resolution
I want standard code for resolution,becaz monitor wise color and tables,alignment are changed.so ineed css code for this
    Scholar:
  • 145 Answers
There is no standard code for resolution. You can't control which resolution the visitor uses. The trick is to have the page look the same no matter what the resolution is set to. You can do this using tables.
You can find a Page Control tutorial here which will explain how to manage this with tables
As for color there are 216 colors which will look the same on any Operating System or browser. These colors are known as web safe colors and can be found here
Does this help?
Posted on May 11, 2009
Tip
How to troubleshoot video issues?
Instruction:
To troubleshoot video issues, follow these steps and test your video after performing each one:
  1. Check the video signal cable connector for bent or missing pins. Check the cable for cuts.
  2. Check to see if moving the monitor connections slightly causes color changes. Tighten loose connections.
  3. In the case of systems with multiple video output connections, verify that the correct connection is being used.
    • Some systems ship with two video connectors on the back, however only one is enabled.
matrix12.jpgExample of a desktop computer equipped with 2 video output connectors.
  1. Standard on board video connection
  2. Optional video adapter connection (some models)
  1. If the monitor has multiple inputs, remove the secondary connections from the computer.
  2. Remove all signal cable extensions and Keyboard, Video, and Mouse (KVM) switch boxes.
    • Use of these devices can result in severely degraded video quality or no video symptoms.
  3. Eliminate wire bundles and magnetic fields from nearby appliances, such as those from speakers, as possible influences on color quality.
  4. If applicable, remove and reseat the video adapter card.
  5. Check to see if the display is visible and check for proper color during startup.
  6. Verify that the video is working by booting to the operating system in Safe Mode.
    • To enter Safe mode press F8 when the Windows logo first appears on the screen during system startup.
  7. Ensure that the most recent video driver has been installed.
    1. Right click on the Windows desktop.
    2. Click Properties.
    3. Click the Settings tab.
    4. Click the Advanced button.
    5. Click the Adapter tab.
    6. Click the Properties button.
    7. Click the Driver tab.
    8. Compare the Driver Version: with the current version and update if needed.
  8. Run the monitor setup program.
    • Some monitors are supplied with setup programs on CD-ROM or diskette. Follow the manufacturers directions.
    • Readability can be improved on some systems by running the Microsoft ClearType tuner.
  9. Check video quality by changing the hardware video adapter to the lowest available resolution.
    4. Use the Screen resolution sliding selector to change resolution.
      The resolution selections available should be limited to the capabilities of the video adapter.
    • Some of the selections available may exceed the monitor capabilities and result in a temporary black screen.
    1. Click OK.
    2. Compare results with other screen resolution selections.
  10. Ensure that the display being used can support the video refresh rate and screen resolution specified in display properties.
    • The manual for your monitor should list the supported refresh rates and screen resolutions.
    • Open the Display Properties dialog box to verify that the refresh rate and screen resolutions are set properly:
      1. In the Properties window, click Settings.
      2. Click Advanced.
      3. Select the Monitor tab to view or change the refresh rate for the monitor.
Notes:
  • Some system boards ship with the AGP slot disabled and plugged. These slots have been disabled at the chipset level and do not work. The plugs should not be removed.
  • Some AGP adapters use a retaining clip, which must be moved to one side to prevent damage when removing the adapter.
  • Setting the video resolution to 640x480x16 colors in Device Manager is not the same as changing the hardware to a VGA adapter. You must change the adapter selection from the installed adapter, i.e. ATI, nVidia, or Matrox, to a standard VGA adapter in the Display Properties dialog box.
  • Some Intel chipsets uses Dynamic Video Memory technology (DVMT) for video memory. The initial memory count can indicate less than expected system memory count.
  • Signal cable extensions and keyboard, video, mouse (KVM) switches are not supported.
on Jan 21, 2011 | Computers & Internet
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
I have a css coding problem
I checked the code and css.
It seems like you solved the problem with a seperate class: a.sidemenu
Witch seems the right solution.
If you stumble upon a thing like that again you can follow the dom-tree and define two menu item with the same class:
#leftcol ul li {
color:black;
#navbar ul li {
color:white;
Tip:
Use Firefox with the firebug addon, works great!!
Mar 22, 2012 | Macromedia Computers & Internet
How do I adjust my website to new widescreen monitor?
Your LG flatron resolution is 1366x768.. just change the settings on display properties at 1366x768, if there no available resolution, uninstall your display driver and reinstall your video driver, the process of driver installation detect your monitor resolution automatic <_>
Jul 11, 2010 | LG W1934S-BN 19" Monitor
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Only getting extra large picture
Please right click on your monitor desktop
Click on "Properties"
Click on "Settings"
Look for "Screen Resolution" down at the bottom.
see if the resolution is "1024 by 768"
if not then make it "1024 by 768"
Also check "Color Quality" is set to "Highest (32 bit)"
If not then make it "Highest (32 bit)"
Click apply and screen resolution will be changed.
If it does not change then please check your graphic card drivers.
Cheers
Nov 04, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
My compaq 5500 monitor is not changing its resolution
The video driver may have reverted to a standard VGA driver or your
video driver has stop working and needs reinstalling.
Sep 20, 2009 | HP Compaq MV 5500 15" CRT Monitor
What is the vga
vga is vidio graphic adapter.
It is software which communicate graphic hardware and operating system.
Jun 13, 2009 | Microsoft Windows XP Professional
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
