Low resolution I only get three options for resolution setting which are not enough I mean I don't see the picture, letters clear enough
    Problem Solver:
  • 9 Answers
Hi, there you need to open the cover of your monitor and check for three ajustments you will see them they are like screw but you have to be carefuly as the monitor is like a TV set it produce high voltage.
one of those screw is for contrast which is the one you need to focus on, if its not there there is a black like plug cable which is attached from the tube and the circuit board that one has got two screws one of those is for contrast try both if not sure (Caution!! that's the one that produces HIGH VOLTAGE) ask some one who know's about electrical appliances if not sure what to do.
Regards,
Colin
Posted on May 11, 2009
I have very low resolution.
Hi betty2293,
Low resolution on your desktop can be for two reasons ,
  1. You have chosen a low resolution from your desktop properties, you need to check this up , by right clicking anywhere in a free area of your desktop , then selecting properties --> settings tab and then you find an option to change the resolution.
  2. If you don't find multiple options to select that means, it's because of no video drivers installed.
  3. Therefore you need to use your motherboard supplied CD to install the VGA/Video drivers and things should work fine for you and you will be able to find multiple resolutions in your settings tab which I described above.
Hope this helps...:)
Aug 23, 2011 | Computers & Internet
Tip
How to change your Windows 7 display settings In Windows 7 there are serveral...
In Windows 7 there are serveral ways to get to your display settings. I have detailed them below in options so that you can access them as needed.
Option 1
Right click on your desktop and select "Screen Resolution"
Option 2
1. Right click on your desktop and select "Personalize"
2. Next click on "Display"
3. Click on "Adjust resolution"
Option 3
1. Click the Start button and click Control Panel
Once you are in the Screen Resolution you can set the resolution you want.
Note the resolution that is set now is a wide screen resolution. If you have a standard monitor the equivalent resolution would be 1280 x 1024.
After you have made the needed changes click on Apply then OK to save your changes.
Note if you are still have trouble with your monitor displaying right you may need to install the monitor drives. Windows is not going to have the actual drivers for all monitors. So in picture below you will see where is shows "Generic PnP Monitor" this means that the computer is using a generic driver. You can access this screen by clicking on "Advance Setting".
If you need to install the monitor drivers the link below will take you through the steps of installing the monitor drivers.
http://www.fixya.com/support/r4290666-install_monitor_drivers_in_windows_7
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Recommended resolution is 1920x1080 but my settings do not show that option. Was working ok, but now screen is somewhat unclear.
In case you can't show the 1920X1080 option (or higher resolutions) either the VGA controller can not handle these resolutions (so they are hidden) or the drivers for your VGA controller are missing. Clarify me your desktop brand/model to come back with more details.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 21, 2011 | Planar PX2710MW Monitor
When i full screen it wont be clear picture even couldn't recognized face........???
Sounds like your resolution is either set too low or your laptop does not support higher resolutions. Check in your display setting to see if the resolution can be lowered to 1024 or lower. Try that and get back to me.
Feb 12, 2011 | Computers & Internet
When scanning a picture, the picture comes out faded even if the picture is clear and crisp.
Most scanners allow you to chose what resolution that you want to scan the photo at and you may have selected too low a resolution, for example for the web. If you want the highest resolution scan you need to select the TIF option if its there. If not, select the highest number available.
When you say its "faded", do you mean when it prints out or when it shows on your computer screen? If its when it prints, obviously it could be a printer ink issue or maybe your printer is set to "fast print", which gives poor resolution and may look how you explain.
Sep 12, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Letters
If you mean just for your internet browser window, hold CTRL and scroll your mouse scroll wheel.
If you don't have scroll wheel on your mouse, and you are using Internet Explorer, go to the view menu, then to TEXT SIZE.
If you want to make the letters on your desktop and desktop windows bigger, go to:
display properties -> settings tab -> advanced -> increase the dpi setting
Or decrease your resolution, right click on your desktop, click properties, then click the settings tab and lower your resolution.
Hope this helps!
Sep 10, 2009 | Hyundai ImageQuest B90A (Black, Silver)...
Web pictures not clear
What version of IE are you running? How old is your laptop?
I had this problem before. Sometimes the settings are set so that images will download faster, the price is a lower quality image.
Pull up an image on IE and if it is blurry, then right click and see if there is an option to reload page at full quality.
Unless you have a fast processor and enough RAM to handle the download images. I would leave settings alone and just right click on images that you really want to see.
Feb 13, 2009 | HP Compaq Presario V2000 Notebook
Canon 20D slr
Take higher resolution pictures? hehe!
Go to the settings menu of your camera, then into the picture quality options and stick it on "high".
High-resolution images will take up more space, so make sure your memory card is large enough to hold the number of images you're going to take.
At 6 mega-pixel (the resolution) each image is going to be around 2-3Mb each. A 1Gb (1024Mb) card will obviously store around 500 pictures. =-]
Aug 20, 2008 | Cameras
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
How to set Resolution
Use the resolution button on the top of the camera by the LCD display. One button is for selecting Flash. One button is for the self-timer. The middle button is for resolution. Press the button repeatedly to cycle through the options. One Star for Basic. Two Stars for Normal. Three Stars for Fine (High Quality). HALF means half the amount of data, perfect for e-mails and screen savers. FULL means full data, perfect for prints.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
