Question about iRiver X20 MP3 Player
I've had 2 crashed iriver X20
When i turn my irvier on the launch programs freeze and then turns off. The blue Initializing screen comes on and the Build Library hour glass come on and turns a couple of times before it stops dead. It this a iriver fault or a problem with the files i am loading onto it? It's happened to 2 players!
  • 15 more comments
  • 1145afa Nov 04, 2007
    yes my iriver x20 crashes and turns off too. I have read the solution but how do i know what type of music will play on my iriver and not have it freeze up and turn off?
  • zobeet Nov 10, 2007
    My iriver was turning on, showing the turning hourglass a couple of times then freezing at 'build library.' I returned it for another, had same problem after loading empty player with podcasts, no music. Now new one freezes immediately at 'build library' and isn't recognized by my PC so I can't even see it.
  • wndnzt Nov 12, 2007
    After loading some musics my x20 now frozens in the building library part...
    but how do I remove the musics from my x20 with it isn`t even recognized by my computer anymore? (I tried in windows vista)
  • Anonymous Nov 13, 2007
    I have the same problem. Startup, Build Library, Initialization and....freeze.
    The device is not recognised at all on USB.
    Does anyone know how could I format the X20 in this case ?
    Many thanks.
  • crabapple Nov 14, 2007
    I've had 3 X20 8gb players freeze on the "build Library" window and returned them in person to have them replaced which they've done.All they can tell me is it is a problem and they are aware it happens.Since I bought mine 5 weeks ago I've just had the third one crash.I'm doing everything by the book including disconnecting properly so there has to be a problem with the software supplied eh?..Dave
  • Anonymous Nov 15, 2007
    I have the same problem. But of course can't remove or delete the files or format as the device never gets past initialising. So isn't detected by USB. Any ideas?
  • sadamien Nov 29, 2007
    I have had the same problem with three devices now. They keep giving me new ones. I agree with mixmaster that the problem is related to bad ID3 tags causing the system to freeze. However, once this error has occurred there is no way to connect to the device to remove the files anyway. The system becomes useless.
  • Anonymous Dec 09, 2007
    Same here. Just by the way, how are you supposed to format a PMP that has no reset
    button, and is basically a brick (as in: not even detected by the PC)?
    Returning it seems the only option.
  • Ravenwere Dec 14, 2007
    Transferred 3 albums and 2 avi's to the x20. It shows initializing screen with the Build Library message and freezes there. Apparently it is something to do with the id3 tags on some music. It is all very well to say reformat but how??? My previous iRiver had a reset function but this does not. Most people have returned the players for replacement!
  • Anonymous Dec 16, 2007
    When i turned on my X20, it just froze on the hour glass until it turns off. How can i format the iriver when its turned off?
  • Ravenwere Mar 29, 2008
    Further to my previous comment. I ended up getting the iRiver replaced - no problems. The comment was that it was the avi format that needs to be modified on transfer to the iRiver. To do this I should have used the software provided. But.. as the software provided is windows based and I run Linux....and no the software doesn't function using wine emulation. I ended up recommissioning an old XP computer.
  • bilgeman Mar 30, 2008
    Wont go out blue screen and say initializing. Where is the magic reset button to get back to its out of the box state?
  • Anonymous May 18, 2008
    I've got "Build library" freezes on screen. The solutions are at FAQ on www.iriver.com orhttp://www.iriver.com/support/faq_list.a...
  • Anonymous Dec 30, 2008
    when i open my iriver x20 4GB it says "internal, file system fail, format file system!". Does anyone know how?
  • bono_u2 Dec 31, 2008
    iriver X20 (4GB) software problem
  • Anonymous Jan 31, 2009
    I have the same freeze problem. Please post here the solution because I can't find it anywhere else and iriver page somehow does not work on any of my computers.
  • krustbot Mar 10, 2009
    same as others. uploaded some P2P shared files to the iRiver and it gets frozen on "build library" (having being disconnected from computer and turned on). is frozen on build library and then turns itself off.
    i disconnected iRiver battery but that didn't work. can't find a reset button. will read on and see what the solution is...
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual http://catalog.gaw.ru/index.php?page=document&id=11348 page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()yandex.ru
Posted on Sep 17, 2009
  • Michelle Dec 03, 2011
    Thank you so much!!!!! I did this and it worked! So incredible! It was hard, but it worked!
    I was going to throw it and I thought I should look for a solution on the internet for the last time. I really didn't believe it will work.
    You're a genius.
I've tried fzymarev 's solution but it didn't work connecting 32-19 pins.
instead i've connected 2 times the pins 9 and 12 (9-enbles and disables the chip, 12-powes the chip).
the 1-st time the i disabled the chip, the second time the chip started.
afterward i've reseted the player from it's menu, and now i'm listening to my music again :D
Posted on Jan 27, 2010
I use a microsd to load files that i havent tried on the device before, to test safely. If it crashes then i can simply remove the microsd and clear it. If the "bad" or incorrecly encoded files are loaded onto the internal memory of the device then you will be unable to clear or bypass the "building library" stage and the device is bricked. Take it back to where you bought it and get it replaced if this happens, that's what I had to do when I bricked it.
Maybe we all need to write to iriver and request much improved firmware that allows wiping of the internal memory BEFORE the build library stage as well as the option to disable or an improvement of the "build library" functionality. A simple solution would be to set a flag in a config file whenever files are added to the device and it doesnt do a build library unless the config flag says new files are present and that it is required.
Posted on Mar 29, 2008
  • 626 Answers
Its is a problem with the music you are putting on the device.
If the songs are from a P2P source or other "shared" site, they are generally encoded incorrectly, or the filenames contain incorrect characters or data.
When your device tries to build the database or library, it gets confused at said errors and freezes.
Easiest solution is to remove all the music on the device (i.e. - format the device) and transfer small amounts of music, 10 or so, until you can isolate the problematic tracks and trash them.
Best of Luck.
Posted on Oct 13, 2007
When I leave my computer, I come back to a blue screen with an hour glass. I cannot do anything except manually shut down the computer.
Assuming that you are not doing anything with the computer and leaving it idle (not running any programs besides background programs such as anti-virus) you may want to check your power connections. Usually when a computer freeze like that is caused by a power flux somewhere. It could be the power supply that is turning faulty due to a bad capacitor. May want to try it out with a good surge protector or a different outlet first before looking into the power supply.
Nov 25, 2014 | Dell Dimension E510 PC Desktop
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
The iMac G4 17" freezes cursor moves but nothing works.
Could be a lot of things. Try running Disk Utility from your install DVD:
http://support.apple.com/kb/ts1417
After that, if issues persist, try booting in Safe Boot Mode:
http://support.apple.com/kb/ht1455
If the issue is resolved in Safe Boot, try removing third party startup items:
http://www.thexlab.com/faqs/startupitems.html
If the issue persists in Safe Boot mode, try a new user.
http://docs.info.apple.com/article.html?path=Mac/10.5/en/8235.html
If issue is resolved in a new user, then you know it's something just in your user.
Delete the contents of the following, where ~ represents your user's home folder:
~/Library/Launch Agents
~/Library/Launch Daemons
~/Library/Startup Items
~/Library/Caches
This will usually resolve the issue.
If it persists in the new user, then the issue is likely with the operating system itself. At this point you should Archive and Install:
http://support.apple.com/kb/ht1710
May 24, 2010 | Apple iMac G4 Desktop
Player will not initial stays on initializing
Sounds like there is an issue with the firmware. Download the firmware install from here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds. If that does not work then it is likely the player is unrecoverable.
Oct 29, 2009 | RCA M4204 MP3 Player
Imac G5 keeps freezing on turn on
Get out your Mac OS disc and restart your computer and get that disc into the drive. You may need to restart with the disc in, but that's ok.
Just restart again with the "C" Key pressed and the computer will launch with the OS disc, and then you can access the file menu when it finishes launching.
Choose "Disk Utitlity" from the file menu and you can repair the system files on your hard disk.
then restart without the disc in the drive.
K
Sep 14, 2009 | Apple iMac 24" Desktop
How can i delete my music from mp3/x20
1. connect it to your computer
2. u have a few options
  • Manually search the MUSIC folder of your x20 and delete the songs.
  • sync it with a program such as iriver 3 plus or windows media player and delte it through the program
  • reformat if your looking to delete everything
hope this helps!
Apr 07, 2009 | iRiver X20 MP3 Player
IRiver X20 movie problem
yea the iriver x20 isn't very reliable when it comes to video files. there could be like 10 things wrong with the codec and even if u fix all of them it doesn't help. your best bet is to convert to wmv using the iriver program or another program like winavi converter. its really fustrating i know but its just how the iriver works.
Dec 18, 2008 | iRiver X20 MP3 Player
Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
Oct 07, 2008 | Televison & Video
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
Accidentally formatted my x20, now OS Vista does not see x20 when plugged in. Is there any way to reinstall the firmware?
firstly reformat the x20 using the device itself...
after that install the iriver plus 3...
there should be something on the program to reinstall it...
i also think that on the disc that comes with the iriver, there is an install that might help...
otherwise try and reformat the comp
Good Luck...
Aug 07, 2008 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
4,188 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
