Drive belt for VT-428E VCR cassette loader would they still be available?? Thanks
  • 975 Answers
YES !! belts are still available , you have to go to one of these ELECTRONICS PARTS shop , Im sure you will get the belts you need , good luck , AJ
Posted on May 11, 2009
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
What is an error 20 message on a Sony VO 9850?
Remove the bottom cover and flip the circuit board out of the way.
Check to see that the capstan drive belt is not loose or broken.
Also, open the top cover and check the drive belt for the cassette transport.
Apr 28, 2011 | Sony VO-9800 VCR
Cassette loads and won't play. Cassette won't eject, or if it does the tape itself hangs inside the VCR. The cassette reels do not turn anthough the head does. I believe the problem lies with the belt...
Hello
There si one belt connected to its capstan motor to reel drive gear assembly to reel up the tape. If this belt has either loose or broken, the fault you described here will occur. To change the belt, you have to buy one new with same diamentions. To get it, you must ahve the damaged belt in hand as sample. Just look at its bottom side, and is there any extra sid screwed into, which can be removed to see and take the belt away from the mechanis. There will be one, with every Toshiba VCR. If so, open it by unscrewing the screws, take out the belt, buy a new one and replace it.
Before doing this, make sure that the capstan motor is rotating or not. Just unplug the VCR from power socket, and replug it again. If capstan motor try to rotate even a single turn, it means that it is OK. Replacing the belt should solve your problem.
If you want anymore asistance, feel free to get me through Fixya. OK.
Feb 25, 2011 | Toshiba M782 VHS VCR
Mitsubishi U51 vcr cassette will not come out
THE BELT COULD OFF COME OFF THE PULLEY THAT IS WHY THE TAPE IS JAMMED
Apr 17, 2010 | Mitsubishi HS-U510 VHS VCR
Drive belts Sony FH-B411
Can be fiddly, get a piece of fine wire thats reasonably bendable, shape it into a J make its length about 5-6 inches. You'll need this to help get old belts off and new ones on. Try your electronic stores for VCR kits and get a couple, they've got heaps of belts.the wire can be copper single strand, about thick as a hacksaw blade.
Oct 03, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Betamax SL-HF500 VCR Cassette won't load
It is caused by components failing due to age. It was manufactured circa 1984 and had a projected life of 20 years. You may find a service centre that will undertake a refurbish but I have no idea where you are so cannot recommend any one.
Jun 17, 2017 | Televison & Video
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Looking for source to replace broken cassette drive belts
find something else with the same size belts there just belts don't have to be same kind i'd go a lil smaller then the old ones
Mar 27, 2008 | Audio Players & Recorders
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
