Question about Panasonic KX-T7630 Corded Phone
Call forwarding I am trying to forward all calls to another office. However i follow the directions of: Prog - 50 - all forwarding calls - then the office number But it still keeps ringing. We have 4 different numbers for the office that ring on everyones phone so everyone can pick up and i have tried to do this at the main switch board phone. Do i have to transfer every ones phone to the same number rather than on one phone Thx Anna
  • Panasonic Master
  • 2,460 Answers
The 50 command is for call forwarding of an individual phone, not the incoming calls. There are several conditions that have to be met to make forwarding work. First, you need your ICD group extension. It's generally 600, but we use 100 or 199 or 200 sometimes. The command is in the back of the Operations Manual (OM) and it is in the form of (assuming 600) *71416009+number#. *7140600 cancels.
http://www.public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
Here's a copy of the manual, just in case you don't have one. Page 192 shows the sequence. You might also look at *710 command on the same page for setting forwarding. It is quicker than the 50 commands and sets the status of your FWD/DND button.
Carl
Posted on May 11, 2009
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
Norstar how to reset call forwarding
All depends on who it was forwarded in the first place. Not enough details given.
Dec 10, 2012 | Lands Phones
I am wondering how to forward incoming calls to a cell phone number if the person they are calling for is out of the office?
You can use Google Voice to automatically forward calls based on a variety of rules. For example, you can have a call to your GV number automatically forward to both the office and cell phone numbers, or you can have the call forwarded to either of those depending on time of day or based on who is calling. Additionally, when the person leaves the office, he/she can quickly change a setting in GV to change the redirect. So, for example, right before leaving the office he/she can set GV to forward to the cell phone; then when he/she returns, GV can be configured to direct calls back to the office number.
Try it at http://voice.google.com. Note that while the entire feature set is available in the US, some or all features may not be available in other countries.
Mar 07, 2011 | Office Equipment & Supplies
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
All your out in coming calls have been forwarded need to deactive
you will deactivate right from the call setting.
Jul 15, 2009 | Lands Phones
Call Forward not working
Sounds like an IPK2. try just entering the forward destination in the first 2 fields. Why would the person being forwarded need calls? If you are forwarding his phone he can't receive calls. unless your just forwarding to vmail. cheaper rates at ldtsnj.com
Mar 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
Call fordwarding
I forward my office phone by dialing 72# and the number.
Your office phone may be on a system that did the forwarding, or you may have to CANCEL call forwarding (73#) before you can set it.
Carl
Sep 01, 2008 | Lands Phones
Norstar T7316 can't make call forward work
This worked for me:
Feature 4, 0 1 (xxx) xxx-xxxx
Mike
Aug 06, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Diverting incoming calls to another office
You have posted this question under the Panasonic system, but have mentioned the Avaya IP Office 5410. I can't help you with that.
However, for the "other user" that has the same problem, if you're trying to forward calls directed to your extension, you can forward them to any outside telephone number by using the Call Forward/Do Not Disturb (FWD/DND) button. The code numbers depend on your telephone system (the KX-T7633 can be used on multiple systems), and how your system was programmed by your installer, so I can't describe the exact procedure. Also, your extension may have been blocked from using this feature by your installer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jul 07, 2008 | Panasonic KX-T7633 Corded Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
506 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
