Question about Sherwood AVR-525 Receiver
The avr RD6502 turn off and stay on stand by mode after turn on.
AVR 270 Receiver turns itself off immediately
Disconnect all speakers from Zone 1 and see if it stays on. If it does, you have a short on a speaker (probably cable). If not, you might have a blown output transistor on Zone 1. I have a DENON that I am fixing that does this, but only when I turn up volume. Creepy. Good luck !
Jan 22, 2014 | Harman Kardon Audio Players & Recorders
Starts in stand by mode, and stays there.
This is usually an indication of protect mode. Try turning on the unit with the speakers disconnected. If the unit continues to behave the same, then the problem is internal to the unit and it will require repair. Please confirm the model to be AVR 110 and I'll try to get more details.
Thanks,
Dan
Jun 13, 2010 | Harman Kardon AVR 110 Receiver
Unit turns on for about 5 seconds and turns off with stand by light flashing
you have shorted output transistors which is causing the unit to go into protect mode. You can try factory reset by turning off unit then holding down speaker a and b buttons then turning back on.
Apr 12, 2010 | Denon AVR-681 Receiver
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Avr 688 shuts down immediately after powering on
Internal problem with power supply or one of the channels. Bring it to a repair facility.
Aug 09, 2009 | Denon AVR-685 6.1 Channels Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
My AVR 235 stays on stand by
Hi...
That sounds like a amplifier module /section that has failed.
Do you ever get power surges at your place?
Oct 05, 2008 | Harman Kardon AVR 235 Receiver
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
The AVR-3300 power-off to stand-by mode
You have a blown amp or a leaky cap and the unit is going in to save mode to avoid destrying the unit.
Take it in for a repair. I don't think it should run more than $50-$75 for a fix depending on what component is bad.
Nov 19, 2007 | Denon AVR-3300 Receiver
Sherwood AVR-525 Receiver Logo
104 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
