Question about GE Advantium 120 Convection/Microwave Oven
Fan on without being turned on and won't stop
I don't know how this is going to help you, jomow, but I have the same problem.
    President:
  • 1,197 Answers
Some microwaves have a sensor built in so if the oven gets to hot the fan will come on to help cool it down. It should shut off when it senses it is cooled down to the proper temp. If it will not shut off the sensor may be defective.
Based on what you are describing, looks like the smart board is turning the fan on without any user input. This could be caused by a loose connection from the user interface, or possibly a cold solder joint on the board. My suggestion would be to remove the control panel and verify all the connections are good, and remove the ribbon cable from the board and clean the contacts with a pencil eraser prior to reinstalling it. Of course ensure the power has been removed before doing all that. Then see if that makes a difference. If that doesn't work, then you are looking most likely looking at a new smart board as that is where all the magic happens
to access the control panel..... Remove the two screws along the top ends that hold the vent grill to the cabinet. Once the grill is removed, the control panel is held in place with one screw on top. Lift the panel up to slide the tabs out of the key way and then replace the board.
u can find the boards either at ebay or at a local repair shop
thank you be safe while repairing....
have a nice day
Posted on May 11, 2009
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Sharp R-520KS - When the door is opened, the light and fan comes on and the carousel rotates. I don't know if microwaves are emitted. How can I stop the fan from coming on and the carousel from...
You can tell if microwaves are being emitted if you get warm standing in front of it (seriously). But I wouldn't recommend that unless you want to cook yourself.
First thing that comes to mind is the door interlocks are out of adjustment or bad. Home microwave ovens are not supposed to operate like that. Some commercial models start the fan right away and run it after the cooking cycle is completed but I've never heard of a consumer model that does that.
Find your closest servicer here and have them take a look.
Sep 04, 2011 | Sharp R-520KS Microwave Oven
I lost my instructions to Cookworks Signature Juicer model no kp60pa. I don't know how to take out dirty pieces Juicer to clean, wash them???? Please, help. Elwira
Well, you won't find any solutions on this web site. It is just for advertising other products so don't waste your time searching.
Aug 31, 2011 | Microwave Ovens
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
No fan noise when cooking.
The internal cooling fan is critical. It comes on automatically whenever the oven is cooking.
If the oven is used without its working properly, the magnetron can be destroyed very quickly.
(This of course is different from the hood vent exhaust fan, which you can turn on and off at will)
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In some models, the motor itself is bad. In other models, it is a bad relay or connection on the control circuit board.
We regularly repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly (with your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the fuse located
It would be helpful if you could reply back with your brand and model number, but I can give you a good answer without it.
First of all, this won;t be a problem with the fuse. When a microwave's fuse blows, the unit will be dead.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not listed, please reply back with your brand and full model number.
If you think the problem is on the control panel, which we repair these nationwide by mail for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 25, 2008 | Microwave Ovens
Microwave Oven Problem
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 10, 2007 | GE JEM25 Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
GE Advantium 120 Convection/Microwave Oven Logo
32 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
