My L.O.T for Acer CRT Monitor (Model No.AC 511)got burnt Now I am trying to replace it but unfortunitly the Voltage & other Necessory information printed on it got erased. Now I wanted to know which L.O.T. should I buy & of What specification?
    Problem Solver:
  • 12 Answers
Explain, what is l.o.t
Posted on Jun 05, 2009
How to solve acer ac 512 monitar haricantal problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 09, 2014 | Acer AC 501 15" CRT Monitor
What to check if no power appear nor light when pushing the power button on after pluging in the ac power
Just looking for burns is not enough. You will have to put a meter to every output and make sure it is supplying the proper voltage.
Apr 30, 2014 | Acer AC 711 17" CRT Monitor
I have LG CRT monitor 17 inch .when i switch on my crt it start sparking sound but not actual spark . the sound was so iritating & sparking shows on screen but not inside the monitor. So what was the...
hi,
You have to replace the flyback transformer of your monitor. Its a high voltage stepup tansformer which provides necessory volteges for the picture tube like Anode voltage, screen voltage and focus voltage. After some years of use the insulation stength of the flyback transformer will become bad and the high voltage will try to discharge trough the nearest ground poit. At that time you will hear the sprking sound. Its because of the high voltage Anode volt is discharing to the ground it will reflect on the screen. Using the monitor in this condition will result in the failure of horizontal driver transistor and even the power supply. Replacing the flybalck will solve your problem.
ok
Aug 02, 2011 | LG Studioworks E700S 17" CRT Monitor
Tick tick sound appear from acer 15" crt monitor power supply circuit
the sound you heard come from power regulator. its just fine, just indicate that part are over heat.
maybe you ill consider replace your monitor with LCD. more friendly for your eye and less power consumption
Mar 08, 2011 | Acer AC 711 17" CRT Monitor
MY ACER AL1916W HAS A RED TINT
the circuit that maintains voltage to the color for the red color is weak and has possible weak or defective parts that need replacement. In this case it could be the high voltage tranformer or regulator at the color compensator circuit that maintains the balance of the color or color pins at the CRT tube. They are becoming weak and the tube may need replacement.
Jul 19, 2010 | Acer AC 713 17" CRT Monitor
Is ACER al2016W monitor dual-voltage?
Voltage Required AC 120/230 V
Yes Bob, you can use it in UK 240V and I believe no adjustments required since they are swithed mode power supplies.
Just to make sure have look at the data label at the back of the monitor it should say AC 120/230V. UK 240 is OK since there is a +/- 10% variation allowed on that.
I got the information out of the specifications on line, so you should be OK.
Dec 16, 2009 | Acer AL2016W 20" LCD Monitor
My acer monitor is not turning on please help i have try evrything
have you try replacing the power cord of your LCD monitor? mybe its defective or not properly plug to an AC outlet. check also the source of your power if its working....it from AC outlet there is a voltage present try to replace your power cord connected to your monitor with a new one
Oct 10, 2009 | Acer AL1923 19" Monitor
Acer AL1717 moniter hissing and goes black
Include me in the people burnt (no pun intended) by crappy quality Acer monitors. Will never buy their stuff again. Ironically, this infrequently used external monitor burnt out overnight, just a few hours after I had actually checked out and decided to buy an Acer Windows 8 15.6" i5 laptop. Definitely not buying Acer again.
Imran
Feb 08, 2009 | Acer AL1717 17" LCD Monitor
CRT Voltage Pin Voltage
What is the problem? Can't fix without info.
Dec 25, 2007 | Acer AC 711 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
