Question about Electronics - Others
I have Magnavox mp3 player MSA2025/37 and it does not turn on. At first it was saying low battery so connected to pc for charging and added music, disconnected and tried it but would not turn on. pls
Mp3 player does not turn on
  • 63 Answers
You May Have A Simple Problem Inwhich The Button Has Come Away From The Power Pad This Can Be Solved Simply By Opening Your MP3 And Makeing Sure The Button Is Connecting With The Pad Properly
Posted on May 11, 2009
My sumsung YPK-3 mp3 player does not charge. When I connect to the PC the usual charging screen comes up saying it is connected and is charging. Even after over 5 hours, it did not charge at all and when...
The battery is at fault. The charging circuit is fine as it says CHARGING. As the battery is at fault you may like to as Samsung to replace it if the device is still under warranty. Else replace the battery.
Jul 05, 2011 | Samsung YP-K3 MP3 Player
Will not charge--will come on plugged into pc tower,but will not charge
it's charging when plugged into your pc, if it doesn't hold power well you may have a defective battery, plug it in and let it sit for 6-7 hours and see how long the battery holds out. if it doesn't work you have a bad battery.
Feb 15, 2011 | Sony Walkman NWZ-S616F MP3 Player
My mp3 player frozzed on my when i was adding the music to my ps3
SOLUTION 1 - Reset the device.
SOLUTION 2 - Re-seat the battery.
1. Remove the battery.
2. Connect the player to the PC to verify if it turns on.
3. Ensure the player's connectors are touching the battery terminals.
4. Re-seat the battery to ensure proper connection.
5. Verify if the player turns on.
NOTE: If the player turns on when connected to the PC but not stand-alone, the battery may need replacement.
Jan 01, 2010 | SanDisk Sansa e250 MP3 Player
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
SAMSUNG YP-Z5 PLAYER NOT CHARGING!
U HAVE 2 RESET IT WIT A LEAD PENCIL IT AT THE BOTTAM IN THE BACK OF THE MP3 PLAYER™ IF THAT DONT WORK I DONT KNOW
Jan 07, 2009 | Samsung YP-Z5 MP3 Player
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
All it says is low battery and charging
The battery life is short - you must recharge every day
Mar 28, 2008 | RCA OPAL M4001 MP3 Player
Player turning on and off when trying to access it
...check that the player is set to MTP mode and don't even have realplayer or WM player open when you connect. Drag-and-drop from your desktop should be working. Also, check the player's HOLD button and make sure the player's battery actually has power! (The PC USB port needs to be "high power" to get juice to the battery...maybe it's not charging?)
Nov 27, 2006 | SanDisk Sansa e250 MP3 Player
Electronics - Others Logo
230 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
