Question about SanDisk Sansa m230 MP3 Player
My computer doesn't recognize the MP3 player
When I first connected the player in the USB plug, the computer recognized it, but something went wrong. Now, it says that it won't work because of an invalid INF file!
I don't know what it is and I don't know what to do!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
When I hook up my Sansa mp3 player to either delete or load music my computer says it doesn'r recognize the usb port
I am not saying that this is the correct solution, but is works for me each time. Just plug the mp3 player into one of the usb ports on at the back of your computer case.
One other thing you can try is:
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this can help you in fixing that pesky “USB device not recognized” Windows error!
Kind regards
Nov 13, 2009 | SanDisk Sansa m250 MP3 Player
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
Sansa e260 does not get recognized by coputer
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated....
Download Update if you haven't yet(
Then connect to your computer and see if it works
Hope it does..........Please rate
Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
Brand new Sansa Clip not recognized in My Computer
try connecting it to other USB slots!!
Nov 04, 2008 | SanDisk Sansa Clip MP3 Player
Computer not recognizing mp3 player
Just got a trutech. I have tried plugging the usb in on several computers and each time I get the same message that windows does not recognize the device. I have tried changing usb chords as well.
Aug 09, 2008 | TruTech SMP-1 GBL MP3 Player
Not recognized by PC
First off.. Make sure your software and drivers are up to date...
Second, try re-installing Windows Media Player or if you have WMP 10 installed, try upgrading to WMP 11.
Also, if you plug in something else to your USB port, does the PC recognize it? Or, if you try your GoGear on another computer, does it work ok?
Apr 06, 2008 | Philips GoGear HDD6330 MP3 Player
Mp3 player
Clean the USB plug, it's probally dirty.
Jan 24, 2008 | BenQ Joybee 102R MP3 Player
SanDisk Sansa m230 MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
