Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Copy feature doesn't make copies
Printing from the computer works fine but when trying to make a copy it seems to go thru the setup but no copy only an error message #0005FBB6 Turn off power, then on again. After doing this still no copy and the same message appears again.
  • 1,170 Answers
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
Posted on May 11, 2009
Photo paper jams when I try to copy print, or copy from computer. Copy paper works fine
Hi Lawrence Lewis,
I would be happy to help you with your Officejet printer. If I understand correctly, you can print and/or copy on plain paper, but not on photo paper, is this correct?
What printer model do you have? How Do I Find My Model Number or Product Number?
Knowing your printer model will help me to better assist you.
I look forward to hearing back from you.
I work on behalf of HP.
Jul 13, 2015 | HP OfficeJet Office Equipment & Supplies
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
HP photosmart copy function does not print with windows 7. I can print and scan with no problem.
it is the version of software that was released to be compatible with win 7. the copy feature was removed. you can try running the original install disk in a compatibility mode
right click on the setup.exe
left click on properties
click on the compatibility tab
check the box for compatibility mode, and choose Vista Service Pack 2
check the "run as administrator" box
right click the setup.exe and use "run as administrator" (yes, this may seem redundant)
Mar 27, 2010 | HP Photosmart C7280 Printer
Get paper mismatch error.doesn't happen if I just copy,but has started giving paper mismatch everytime I try to copy from computer. I have tried everything suggested in tutorials. It doesn't copy if I just...
Clean the sensor on the right side bottom of the carriage assembly with a damp Q-tip. That sensor gets covered with ink and can't see the paper properly. You clean the underside that looks down at the paper as it passes thru...
Jul 21, 2009 | HP Photosmart C5580 All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP 2410 prints & copies fine but won't scan.
Well if you are able to copy from your printer,it suggests that the hardware is perfectly fine.Its just an issue with the software.May be you are using an old software that is not compatible with the new operating system of your computer.If this is not the problem then try uninstalling and then reinstalling the software.And mind that when to uninstall the software do it completely from the registry,program files as well as add/remove programs.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
Copier feature (Black or Color) only produces a Black page
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
May 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP psc 2175 skips when "copy"
replace the black print cartridge. I guess that the text is B&W. Pictures are printed in color - from the color ink cartridge.
Mar 20, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
242 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
