Yahoo PC to PC call firewall conflicts
A network error occurred while connecting to the server when i start yahoo PC-to-PC call
  • Lokesh T D May 11, 2010
    Have you checked with your firewall? check if it is turned on and if it is in off state check with your antivirus firewall
    Sergeant:
  • 239 Answers
Try to disable the firewall..
Posted on May 22, 2009
Why does it say communication error when i try to activate microsoft office 2007
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
May 25, 2014 | Microsoft Office Word 2003 for PC
Ok i have 20 firends in conflict lgobal storm they live in difrent countries and once they were all online so i craeted a mach and 1 by 1 asked them to come and for all my friend it sayd server not avaible...
There can be particular issues related
to playing through a router or firewall,
including sharing your internet
connection via another PC. In order to
join or host a Conflict: Global Storm
game from behind a firewall you must
open the following ports (inbound and
outbound):
UDP ports 4658, 6500, 10010,
13139, 27900
TCP ports 4658, 6667, 28910,
29900, 29901, 29920
To host a game from behind a router
with NAT (Network Address
Translation), or a firewall, you will
need to enable ‘port forwarding’ on
the following ports to route data to the
IP address of your PC;
TCP port 4658
If you continue to have problems
connecting to servers or creating
them, try bypassing your router or
firewall by connecting your PC directly
to your broadband connection.
If possible make sure you or your friends are not behind NAT or firewall. It is much easier to connect if you have all public IPs and not something starting with 192.168...
Do not use ALT+TAB and do not enter Windows when multiplayer is running. It will kill the connection to GameSpy servers that are needed even when you are creating server to your own computer.
Sometimes in the lobby the server just dies quietly and you need to the restart the whole game. You will notice this when players just stop coming to your server. This usually happens because you switched to Windows even for one second and sometimes it just happens without any reason.
Jan 09, 2010 | Eidos Interactive Conflict: Global Storm
Online session making problem
outbound):
13139, 27900
29900, 29901, 29920
TCP port 4658
Dec 25, 2009 | Eidos Interactive Conflict: Global Storm
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Jun 05, 2009 | Yahoo Messenger
Logitech Webcam problem connecting to a server
Temporarily disable your firewall. Does it connect then?
May 14, 2009 | Logitech QuickCam Pro 4000 Webcam
It says :"you have been disconnected from online servers"
outbound):
13139, 27900
29900, 29901, 29920
TCP port 4658
Do not use ALT+TAB and do not enter Windows when multiplayer is running. It will kill the connection to GameSpy servers which are needed for connecting to any internet server.
Apr 26, 2009 | Eidos Interactive Conflict: Global Storm
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
Server error on Yahoo when connecting
Check your firewall many are having this same issue especially with Norton
Oct 22, 2007 | GE EasyCam Plus Webcam
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
