Question about Dishwashers
Had standing gray water under house got the water out and fixed the drain problem but still have the smell How do we get rid of the smell of the stagnent water its bad. Thanks
I have a bad smell coming from under the house as there was standing gray water from the sink drain we got the water out now we have a very bad smell how do we get rid of the smell thanks
  • dko123 May 12, 2009
    thanks will give some of these a try and let you know what happens
    President:
  • 1,865 Answers
Many commercial cleansers are good for neutralizing odors, but several common household products can be used as well. Vinegar is an extremely versatile grocery item that neutralizes many odors, including those left behind by pet accidents and skunk sprays.
Baking soda, whether applied dry to an area or mixed and sprayed with warm water, is another effective way to absorb and neutralize household odors. Baking soda carries the added benefit of absorbing moisture, so it often makes a good secondary application for a moist stubborn stain causing an odor. Citrus fruits like lemon and oranges deodorize and leave a pleasant smell behind. Using citrus juice on fabrics is not usually recommended, but they are good for things like running through garbage disposals.
Posted on May 11, 2009
Gray water will not drain suspect clog in tank outlet. how do I fix?
How to Drain the Grey Water From the Washing Machine ...
homeguides.sfgate.com > Foreclosures > Other Foreclosures
A washing machine produces grey water that typically contains dissolved detergent and dirt -- but not contaminated waste -- so it can be a valuable source of ...
How to reuse grey water in the home and yard : TreeHugger
www.treehugger.com > Living > Green Home
Jun 2, 2014 - If you just crawled out from under a rock, you can be forgiven for notknowing that ... Grey water can be used for watering houseplants, landscaping, ... thedischarge hose from the washing machine from the house drain, and ...
How to Make a Laundry Water Recycler (Gray W
Dec 25, 2015 | Washing Machines
Car smells musty needto know where drain plug is located
the drain plugs are located under the floor mats in the floor pan . If you look from underneath you will see the round plugs .If the carpets have been wet that bad then you will never get rid of the musty ( fungus) smell . consider new floor mats
Apr 15, 2014 | 2004 Chrysler Sebring
My dishwasher stinks like eggs
If the unit is not draining completely you may get a smell. I would use Affresh in the unit and see if this gets rid of it. If not, it might be an issue with your water. Do you have well water? Sulfur in the well water can sometimes cause this issue.
Sep 01, 2011 | Whirlpool 24 in. ADP5966 Free-standing...
The washer smells funny. Like mildew or something. No water standing. Seems to drain.
Probably has some standing water in the pump hoses as well as the drain hoses If you do not use the machine often, then some water is left in the drain hoses and upon evaporation it may do what you smell. Pour some bleach in the tub, with water and let stand for 15 min. put it on rinse and let drain and do the smell test again.
Jan 09, 2011 | Whirlpool WTW5300SQ Top Load Washer
Evaporation tray at back of stand alone refridgerator is full of .....? and smells. How do I clean it as it is fixed to the back of the fridge?
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Aug 04, 2010 | Zanussi Refrigerators
I need to know how to get up in the air vents there is an awful smell coming from them
This Is Indicative OF the EVAPERATOR Housing DRAIN PLUG Getting CLOGGED and REQUIRES that you Locate the RUBBER TUBE Under the Passinger Side of the Vehicles FireWall and USE a Long PEN or PENCILE to POKE into the TUBE to Free The DEBRI that is CLOGGING it Up, The Smell is of OLD MILDEWED WATER from A/C Condensation. UNPLUG the DRAIN TUBE and THIS WILL Let this Smelly Water OUT thus Getting Rid Of the SMELL.
Jul 01, 2010 | 2004 Dodge Stratus
Water is not completely pumped out of machine, I can hear it sloshing under the bowl. Have taken back off and tipped machine and some water has come out but not all of it. It is making the house smell...
sounds like you may have some blockage between the tub and pump or pump to stand pipe where water goes down the drain,check all these areas for blockage or kinked hoses
Jan 25, 2010 | Washing Machines
Smelly airconditioner
Smell is more than likely from standing water in the blower housing. In front of the pssenger under the hood, there is a box mounted on the firewall. That is the bloer housing. Under that housing is a drain that commonly plugs up from slime. Locate it and it should come off by squeezing it. You will see how it goes back in once you have it out.Clean the drain and woirk it to break its form. They have a tendancy to harden and stay closed. It should be soft enough to open by the fan pressure in the housing. Clean with your pinky as best you can in the box.
Oct 27, 2009 | Panasonic Heating & Cooling
Mildew smell
water may not be draining completely out cause something is stuck in drainage area.
Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
625 people viewed this question
Top Dishwashers Experts
