Question about Philips 42PFL5332D 42 in. LCD Television
Hdmi issue i cannot get signal from my direc tv reciever using hdmi cables
It worked for me after I upgraded the Philips TV firmware. It broke again stopped working last week.
Philips TV firmware - you can get it from the Philips website. (I suspect Direct TV issues a software upgrade and broke it again)
Posted on Feb 26, 2008
  • 661 Answers
This may sound silly, but are you changing the channel to the HDMI channel (one of the AV channels)
Posted on Oct 12, 2007
  • Gareth Cockram
    Gareth Cockram Oct 15, 2007
    blimey a bit more information might have been helpful before giving me a "not Helpful"
  • Gareth Cockram
    Gareth Cockram Oct 16, 2007
    ok...it's either the TV, your decoder box or the HDMI cable
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 | LG 55LM6700
I am having HDMI output issues to my HD TV. The issues are intermmitent. I have my HD cable box, BluRay Player both hooked into the reciever via HDMI. The Hdmi output of the reciever feeds my TV. I have...
Have you proven that a straight shot HDMI to the TV from either source solves the problem?
For all we know the TV or it's HDMI cable could be faulty.
Apr 09, 2010 | Onkyo TX-SR606 Receiver
Can not get the listings for the TV Guide to load. The TV is connected to cable box and tuner with HDMI cables. When I contacted LG they stated that I need to split the cable signal prior to connecting...
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 01, 2009 | LG 50PX4DR 50 in. Plasma TV
Denon avr-1908 no picture from dvd player which is a panasonic...using hdmi cable
if your not getting a picture make sure you have change you signal setting on the reciever if you have done that. and you know your connections are right and you you are going from your dvd into the reciever and then the reciever to the tv with hdmi check you tv as well make sure you have switched your input signal to to the video source were your plugged into the tv i dont know what kind of tv you have but you may need to double check that
Nov 11, 2009 | Denon AVR-1908
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
Connected to direc tv box with no sound or pic
The PS3 is connected to your TV via one of the inputs on the backside of the set? If so, the input you used can be selected from the remote or from your menu buttons on the physical TV. The remote will have a button labeled video(video inputs) and by depressing it you can scroll through different selections ie... Svideo, TV, colorstream 1 & 2, HDMI(which is probbaly the best, but you will need an HDMI cable)
Apr 08, 2009 | Sony Playstation 3 (PS3) Console
Panasonic CT-32SF36 isn't getting video from A/V receiver
Hello, I hope this message can help you, After reviewing the Panasonic TV info, and the Yamaha reciever info., I have found on page 19 of your owners manual for the Yamaha reciecver that you can connect the the cable box HDMI cable to the reciever, but the reciever needs to connect to the T.V. HDMI.
I see your T.V. has S-video in and your reciever has S-video out, what about your cable box if it has S-video than I would connect all your device together through the S-video jacks.
A further note is you can't down grade the signal from the cable box through the reciever to the T.V., so even though the technology is there on your cable box, it's not there on the T.V.. On that note there is 2 options 1) buy a new T.V. with HDMI inputs. 2) connect the system together using S-video or component cables (RCA). It will give you almost the same quailty if you use good cables. I hope this will help you and I look forward to helping you in the future.
Jan 14, 2009 | Panasonic CT-32SF36 32" TV
Receiving "Unlock" message and "Not Used" on my reciever
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock" and you will get sound. The only purpose for the HDMI jacks on this reciever is to give you a bonus HDMI jack so you only have to use one on your TV. I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's.
Dec 30, 2008 | Sony STR-DG520 Receiver
Need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
Dec 25, 2008 | Sony STR-DG520 Receiver
Philips 42PFL5332D 42 in. LCD Television Logo
321 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
