Picks up multiple pages - Office Equipment & Supplies
    Problem Solver:
  • 11 Answers
Try fanning your paper from all 4 directions before printing. This seemed to help me.
Posted on Jun 09, 2009
What to do about the ADF pulling too many sheets through?
Make sure the pick up roller is free of paper dust. You can get cleaner paper at an office supply store. It is sticky on both sides and will remove paper dust from the surface of the pick up roller.
Aug 21, 2014 | Panasonic Panafax Uf-8000 uf8000
Printer feeding multiple pages
you need to cleaan the friction pad. it is under your paper where it picks up. or replace it.
Feb 06, 2014 | Samsung "scx-4623f multifunction laser...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My HP Deskjet 1220C printer picks up several pieces of paper when only printing 1 page. Picking up multiple pages when ony printing 1 page.
THE SPERATION PAD IS DIRTY OR WORN.TRY CLEANING THE SEP PAD WITH NAIL POLISH REMOVER.THE SEP PAD IS LOCATED UNDER THE ROLLER THAT PICKS UP THE PAPER
Feb 28, 2010 | HP DeskJet 1220c InkJet Printer
Doc Feed Problem
I would replace the Pick-up roller, Feed Belt, Sepearation roller, and torx Limiter for starters IF you cannot replace them, Clean them with warm water and soap, let them dry, and try the doc feeder, Most Multi feed problems are Torx limiter or clutch problems.
Apr 11, 2009 | Office Equipment & Supplies
Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
MULTIPLE FEED PROBLEM
There is a little with pad that is called the seperation pad. You can see this under the pick up rollers. Clean this off with some alchohol. It may fix the problem. If not a new pad is needed.
Speration pad needs cleaned or replaced. Its a $10.00 part.
Jan 09, 2009 | Canon PC1061 Copier
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
Aug 05, 2008 | Office Equipment & Supplies
77 people viewed this question
k24674
jasbo
jasbo
