Drum speed is too fast then sometimes does not rotate
My unimac washer whhel does not turn
    Scholar:
  • 43 Answers
Try just opening and closing the door. Sometimes cycling this switch fixes problems with washes not advancing.
Posted on May 11, 2009
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
Unimac. Why is it displaying E FL and won't spin?
Unimac Washer Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/unimac/washer/
Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Jan 07, 2016 | Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Unimac front loader washer with the error code OF not sure what it means. This is a stackable unit.
[PDF]Operation/Maintenance for Drying Tumblers - Alliance ...
docs.alliancelaundry.com/tech_pdf/Production/70283501en.pdf
NFPA 54 "National Fuel Gas Code" and Standard ANSI/NFPA 70 "National Electric Code." In Canada ..... NOTE: If display shows an error code, refer to.
Oct 15, 2013 - I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was ...
65 lb Capacity UWN065T4V - UniMac
unimac.com/products/unimac-washer.../high.../65-lb-capacity.aspx
A description for this result is not available because of this site's robots.txt - learn more.
e OP error - YouTube
Dec 15, 2015 | Washing Machines
Error code LE what does it mean
The LE error indicates that the Controller is having trouble communicating with the motor.
The most common cause for this is if something gets wedged in and the drum can't turn freely. Try turning it by hand to make sure it is free. The next most common cause is if someone spins the drum moderately fast with the washer turned off. I.e. if you give it a spin to make sure their isn't a sock stuck to the drum.. To fix this, unplug the machine and turn the drum counterclockwise 4 full rotations followed by 4 rotations clockwise at low speed. Plug it back in and see if that fixes it.
If that's not it, then there is a sensor called the Hall Sensor that could be the problem. I've never had to replace one of these and can't comment further.
GL
May 11, 2014 | LG WM-2277HW Front Load Washer
Unimac washing machine is displaying FULL & cant open the door
Try unplugging the machine for a few hours to rest the code on the board.
Oct 14, 2013 | Unimac Parts Unimac 1300757 Washer HOSE,...
Need AC Drive for UniMac washing machine
Contact Laundry Systems of Nevada. They are a Unimac dealer.
Aug 07, 2013 | Unimac Parts Unimac G581P3 Washer KIT,...
Agitator drum only rotates in one direction
yeah it sounds like the programer has failed this part is expensive
shaun
Jan 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin
check the belts not too lose....
cheers
Aug 03, 2017 | Whirlpool LSR8433K Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
