Question about Pelco DX1000
RESET PASSWORD FOR DVR PELCO DX4000 - Pelco DX1000
4 Suggested Answers
SOURCE:
SOURCE: i have pelco dx 2000
yes, on the configuratiion plage, use the schedule to increase the amount of time you want for
1) Sechedule recording
2) motion recording
3) event recording.
Remember, this is all based on the size of your hard drive and the number of camera you have installed.
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Posted on Aug 10, 2009
  • 5 Answers
SOURCE: I have 6 pelco make 5104 dvr connected to a
I've had numerous problems with my Pelco equipment over the years, they launched some new online help community where a tech rep will provide you with solutions and links to software relatively quickly.. http://buildingscommunityhome.schneider-electric.com/Signin.aspx Calling customer service hasn't worked out so well for me in the past, so far their online support seems to have their act together
Posted on Oct 25, 2012
How do I reset forgotten password on Pelco dx4140 Dvr?
Best thing to do is call the manufacture and they will assign you a generic code and you can take it from there
Jan 02, 2018 | Pelco Home Security
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
I recently bought a DVR, a Pelco DX4000 Series. I have been trying to link this DVR to my laptop for my security cameras. It DOES connect; it's just not showing live video. It does show the live video on...
You need to install the Video drivers and enable the "Overlay" I suspect, you have not got the latest Video drivers for your card, go to the cards web site, ATI, NVIDIA etc, and download entire package and install.
Mar 08, 2010 | Televison & Video
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
My pelco DVXe dvr display is at minimum not 32 bit cant see pics
boot into bios and set your display for vga mode. At least that worked for me
Apr 09, 2009 | Pelco Home Security
I have pelco dx 2000 dvr of pelco brand i just want to know can i increase the recording days with new high rating hard drive from 90 days to 120 days
2) motion recording
3) event recording.
Jan 14, 2009 | Pelco DX2000 Series 16-Channel 80GB DVR
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Page chaging
This DVR dose not support that...You can either see one camera full screen or see all 4 in a quad screen depending on how many cameras you have and how may of them are enabled.
If the Preview feature in the Camera menu is On, you can view live video on the monitor.
Video is displayed full-screen only if one camera is turned on. If more than one camera is
turned on, video is shown in a quad view. Sorry but its not going to be able to do what you are looking for...Pelco didn’t put that feature in their small DVR until the DX4000 series......Good Luck and let me know if this helps,
cbinny1
Apr 19, 2008 | Pelco DX1000
Open Questions:
Pelco DX1000 Logo
205 people viewed this question
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
