Question about Dell 1700n Laser Printer
Dell 1700n error light after print job.
I have a Dell 1700n that boots up normally but when I press "continue" to print a test page, it prints two pages and then the error light illuminates. It's solid, not blinking.
I press continue again and it prints two more pages and the error light comes on again.
Any ideas?
  • Anonymous May 22, 2009
    Ok well I did that and it only says Load Remove Paper. I have no idea what it wants. I've tried everything I can think of.
  • 433 Answers
Double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
Posted on May 15, 2009
My Dell 1720 copies tells me it has stopped because the photoconductor kit has stopped working. I just replaced everything and keep getting the same error.
If the drum cartridge has not been replaced, it must be replaced before resetting the counter to avoid damaging the printer.
  1. Power off the printer.
  2. Open the front door.
  3. With the front door open, hold down the Continue button while powering on the printer.
  4. Keep holding continue until all lights start flashing then release the button.
  5. Once only the Error light is on, close the front door.
  6. At this point Continue, Ready/Data, Toner Low, and Load Paper should all be lit.
If the previous set of steps did not go as described then do not continue. Please complete the previous set of steps again.
  1. Wait for the printer to make a sound as though it is about to print something. (This may take a minute.)
  2. Press Cancel 4 times SLOWLY (1 second between presses) to cycle through lights until ONLY the Toner Low light is on. (It may take more than 4 presses.)
  3. Press and hold Continue until all the lights cycle through and go back to Toner Low
  4. Cycle power on the printer.
  5. Press and release the Continue button to print out the settings page. Under Cartridge Information it should read Photoconductor: 0K
Aug 04, 2010 | Dell 1700n Laser Printer
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
To reset the counter, press and hold the Cancel button until all lights flash in sequence.
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
I swapped Photoconductors from 2 other 1710's; no go. Reset?
Problem
Dell 1700 printer prints out a page announcing that “the photoconductor has reached its useable life and it needs to be replaced for a new one”. You replace the photoconductor for a new one and the error light is still blinking and the printer keeps on printing the above mentioned page.
Solution
Steps to Reset the Photoconductor:
  1. Power off printer
  2. Open the front cover.
  3. Press the continue button; while pressing the continue button power on the printer and wait (still pressing the continue button) until the error led is solid, then release the continue button.
  4. Close the front door, all light should be solid.
  5. Wait until POST finishes.
  6. Press the Cancel button 4 times slowly, the toner led should be solid.
  7. Press the Continue button until all lights go up and down, then release; the Toner Low led is solid.
  8. Power off printer and then back on.
  9. Press continue button once, print a test page.
  10. Check the information about the photoconductor in test page, it should display an OK status.
Note: if these steps don’t work for the first time repeat three times. If still the steps don’t work, the printer needs to be replaced for a new one.
Jun 26, 2009 | Dell 1700n Laser Printer
How do I get a page count on the Dell 1700??????????
well on mine if you just plug in the power cord ONLY with nothing going to the pc and press and hold the continue button it will print a test page with count
Aug 07, 2008 | Dell 1700n Laser Printer
Dell 1710
If that is the only light:
Remove the toner cartridge and firmly shake it from side-to-side and front-to-back several to use the
remaining toner, and then reinsert it and continue printing. Repeat this procedure multiple times until
the print remains faded. When the print remains faded, replace the toner cartridge
If not let me know.
Nov 16, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
352 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
