Can a washing machine motor and assembley be found if not available fron manufacturer and what do you think of what I described with regards to the dryer
Dear Expert,Sir or Madame, I truly need your advice and assistance. I will be thorough and patiently await your response and help. I have an excellent washing machine and dryer combination which my father purchased April 25th,1985. In 2000 or 2001 we changed the washing machine motor. In November 2008 after drying two loads the dryer would not start. An appliance technician said I needed a new dryer motor but could not order it from his warehouse and wanted nothing to do with it. I found a veteran technician who discovered it was only lint that impeaded it's function. He heard when pushing in the start button a noise from below the timer knob. It has worked beautifully until last evening when the same occurred and the same noise when pushing in the starter button. If I decide to I can get all the dryer parts necessary.It may cost over five hundred dollars. But if,for the future I wish to stock up a washing machine motor and assembly for when this one breaks down I am told by both Sears & Roebuck and Repair Clinic.Com that the washing machine motor and assembly are no longer available. Is there any where in all America or elsewhere this can be found? And can the washing machine motor be repaired if need be in the future? Also what do you think of the dryer problem? Below are the details of my machine : Name: KENMORE ALL IN ONE LAUNDRY SYSTEM Series: LAUNDRY SYSTEM MODEL 93901 Model Number : 41789390800 The last number which Sears & Roebuck designated for the washing machine and assembly was 078394-100. Repair Clinic.Com has 5308011236 which is an error because this number is for the dryer motor and switch assembly. Please help for if I can repair and also stock up with a washing motor it will save me money in these difficult cautious times we are in. Awaiting your reply. God Bless, Eric Galati
  • 240 Answers
SOURCE: F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
Posted on Jun 03, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore Front load washer #417, basket assembly fell out
hi. thanks for the question. i would go to Sears customer service .and demand a replacement washer
Posted on Oct 05, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Posted on Mar 10, 2009
  • 1937 Answers
SOURCE: Kenmore 70 Series Washing Machine Just Hums (Won't Agitate)
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22712100
Also see the Whirlpool / Kenmore service manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are a worn/broken motor coupler.
See the following for how to get to it and check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=6019c5e82bfa177df953f5d6ebeac983
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
It's possible that the prongs have broken and the humming that you hear is the pieces rubbing against the center rubber piece.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 10, 2010
Testimonial: "Awesome - Thanks!"
May tag Neptune 5500. The door locked light never comes on and door is not locked in any cycle. How do I test the switch/lock assembley? And is there a way to trick the machine into thinking that the door...
Grounding in a 120vac environment usually will cause a big spark and pop the circuit breaker. There is a possibility the latch is like a car door latch. If it somehow gets moved to the shut or latched position when the car door is open, it will never close and latch . The latch must be returned to it's normal door open position so that when closed it will latch securely.
Your machine's latch may be blocked by something acting like the car door latch described above. It may be the switch has broken and is the "culprit".
Mar 26, 2015 | Neptune Washing Machines
Washer will not drain on the spin cycle
since the spin cycle is high speed, you may actually have a problem in the door lock safety switch
Oct 26, 2014 | Washing Machines
Bosch Maxx WFL 2450 Washing machine Electric fault
hi there ...it sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
regards Sir Galahad
Aug 18, 2009 | Washing Machines
How to change a washing machine belt
Unplug machine. Remove back panel. loosen three nuts holding motor clutch assembley from bottom side of motor mounting plate with deep well socket, allowing motor mounting plate to slide. Remove clamp holding flexible drive coupler just above belt. Remove belt. Reverse to install, but remember to give a little tension to the belt by holding motor toward the back left corner while tightening up nuts. Tighten the nut closest to the center of the machine first.
Jul 09, 2009 | Washing Machines
Frigidaire Gallery FWT449GFS1 washing machine
Call a few hardware store....I think I found my brushes at True Value. Then take the brushes/case & spring to a lawn mower etc. repair shop...they charge you a few bucks to get the right angle and length with the spring and case. Hope it helps!
Jan 24, 2009 | Frigidaire FWT449
Not spinning
OK, if the motor is spinning but not turning the clutch hub, that means the transmission is jammed. You may be able to free it by manually turning the big pulley on the bottom of the transmissiion, but the problem will reoccur. The real solution would be to replace the transmission assembley in this case. (Transmission WH38X1002) Check the last pages of your users manual for warranty info. Warranty will vary based on model and date of manufacture. Typically, transmissions will have a 5 years part only warranty.
Aug 28, 2008 | GE Profile WPSR3120WWW
Kenmore top loader
Hi I see your having the washing machine won't spin problem. The first thing I would sugest is to disconect the AC power from the machine. The next step is to remove the front panel from the machine. Look at the top lid for a plastic tip that fits into a keyhole in frame. Underneath there there's a safty switch. This switch is designed to stop the machine from spinning if the lid is open. Sometimes the switch gets corroded over the years. It may have to be replaced or adjusted to align with the plastic tip whin the lid is closed. The black thing hanging down from the motor you described could just be some electrical tape the manufacture uses the bundle the wires from the motor. Some manufactures use a spring to keep the wires from the motor from interfering with any moving parts. Hope this helps.
Sep 06, 2007 | Washing Machines
Open Questions:
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
