Question about Car Audio & Video
I dont have no power for me 2 connect my stereo i think a fuse is blown and i dont kno which 1 it is
    Problem Solver:
  • 16 Answers
Can you please specifice what is the problem,if u are using a sub you must make sure you have powwer coming from the amplif
Posted on May 11, 2009
1986 Thunderbird troubleshooting
there are 2 fuses boxes in cab and 1 in engine bay
we test the fuses, we dont change them out willy nilly.
even better, is to measure the voltage at at the radio.
the power pin is 12vdc, keyon
if not the fuse is blown or the wire is cut.
end story.
my guess is car wiring was hacked long ago with stereo upgrades
or other hacks, (alarms,etc)
old cars are like that, hacked.
May 10, 2014 | 1986 Ford Thunderbird
Car stereo short circuit. Won't start.
Worse case, fried body ground. Which will feed fuel pump. And surrounding circuits. Check every point for a good ground to body. Then check fuse panel for blown fuses.
Jan 15, 2014 | Cars & Trucks
1997 ford contour tail lights won't work but brake lights do already changed bulbs what fuse is for parking light
There are 2 fuses,left and right, so I dont think both could be out? fuses. 33 and 35. make sure they have power on both sides of the fuse. If one side has power, its blown, if no power, the headlamp switch is bad, or bad connection. The RED/BLACK wires coming out of the headlamp switch go to those fuses. 33-35
Dec 10, 2010 | 1997 Ford Contour
So I connected 8 speakers to this system and I might have blown it out. when i connect it the red standby light comes on. then when i press the power button the screen goes blank as if turning on but...
Audio output shorted out or blown fuses in power supply check all fuses if fuses are good your Audio out put transitors or I.C has been shorted out as a result of impedence over load in future dont connect speakers in parallel in those small Audio units.
Natureisland technician
Commonwealth of Dominica
Nov 06, 2010 | Sony CMT-HP7 CD Shelf System
My stereo is not coming on.. the time will illuminate when i press the display button and the lights behind the buttons will come on but will not turn on.. the cd will eject as well but thats it..
Sounds like the fuse for the switched power has blown. The stereo has two power inputs -- one unswitched, called "memory" because it lets the stereo remember your presets, and one switched, just called "power"
It should let you see the time, eject a CD, etc all when the car is turned off. Since the fuse for the main power line is blown, the stereo thinks the car is turned off all the time.
Feb 13, 2010 | JVC Car Audio & Video
My Car Stereo Broke
Fuse #13 15 Amp located to left of steering column in dash. Radio, cig lighter and lcd display.
Mar 29, 2009 | 1996 Jeep Cherokee
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
The amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Feb 10, 2009 | Kenwood Excelon KAC-X521 Car Audio...
My dash lights don't work.
this got easy after a while 2 ways, i had friends who would not take the time to spend 8dollars to buy a harness connector for a new cd player and would splice everything together like takeing the red and yellow wires and connecting them all together as one. this drains ur battery unless ur cd player can completly power down by the power button not all do... but keep this in mind on GM cars the 2 wires of the same wires like purple the one with a black stripe is ground they go together stripe on stripe also there is 2 extra wires one is ORANGE and BROWN u dont need these dont even mess with them even if u have a connector block them off THESE TWO COLORS IS FOR FACTORY STEREO IF SO THESE WIRES CAN AND WILL MAKE IT SO U DONT HAVE DASH LIGHTS so always buy a connector ond dont mess with these wires block them off and dont ground them out.
Jan 12, 2009 | 2001 Chevrolet Blazer
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
