Question about Car Audio & Video
Broken part on my insignia amp need replacement part
I have an insignia amp that the a/v jacks broke of where can i find spare parts?
    Problem Solver:
  • 19 Answers
Try your local electronics store, or best buy since they are the makers of insignia, not a bad brand of amp for how cheap they are, i owned a few, and if you have a warrenty just take it to best buy and they will replace the whole thing for free.
Posted on May 11, 2009
Audio input jack for headphone component broke off need to find new input and how to replace
No way to do that unless you can figure out a way to remove the part. The contacts inside that plug determine where the sound goes. No way to turn it off unless you remove the broken part. If you feel confident enough, remove the back of the TV and remove the broken piece from the jack.
Mar 02, 2014 | LG 32LD350 32 in. LCD TV
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
Jan 13, 2013 | Dell A920 All-In-One USB Color Inkjet...
Slik U-102 pan head platform broke into pieces. Replace?
Send some pictures to email@spartanphotocenter.com and we might be able to see what the issue is. Unfortunately, Slik doesn't carry spare parts so if the entire pan-head is broken you may need a new tripod.
Jan 03, 2013 | Photography
Beringer xenyx 1204 repair
OFTEN the broken part CAN BE RETREIVED without removing the faceplate. There are MANY knobs and screws to remove to get at the jack AND then, the jack is mostly sealed and one cannot get into the innards of the jack.
I want you to try a few things before tearing into the unit. Here are ideas to try, not necessarily in prefered order as I can't see your unit and the broken part.
1. Take a very thin sheet metal screw and try to drive it GENTLY into the broken adapter. OFTEN you can snag the thing and drag it out.
2. Take a sewing machine needle and STAB the plastic insulator of the broken part and attempt to drag it out.
3. Attempt to epoxy glue a small dowel to the broken part. Use minimual glue so it doesn't squish out to the sides of the jack.
4. If the broken part is iron, try using a small rare earth magnet to **** the thing out.
5. If enough of the broken part is near the surface, attempt to solder a wire to it to use to extract the broken part.
6. Using a sewing machine needle and a soldering iron, melt the needle into the plastic insulator of the broken part.
I am sure one of these suggestions will work. The jacks themselves are sealed all the way around and you would have to unsolder the jack from the board. You would either replace the jack, or drill a hole in the bottom of some of them to be able to push out the broken part. All of this internal type work has risk to the unit if you are not equiped to do the work. If you can snag the thing with the above suggestions it will be quicker and safer.
Nov 28, 2009 | Behringer Music
Cable broke off in the input jack
I'm pretty sure t6hat the output jack is a sealed unit(contacts inside soldered to the surface of the circuit board. You may be able to grasp the center shaft of the plug with a thin jawed hemostat or really skinny long nosed pliers and pull it out that way. Make sure the amp is off and unplugged from the wall. If that doesn't work you will either have to get it removed at a shop or disassemble the amp to remove the circuit board and unsolder the jack and replace it or get the broken plug out of the jack once it is unsoldered. I've never had a Line6 apart yet but thats probably the type of jack they used. Thats because it has to be electronically isolated from the chassis. Hope this helps.
May 15, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Broke rca jack
You can buy replacement panel mount RCA (phono) jacks directly from your local radio shack if you have one, or on www.radioshack.com a 4 pack is less than 5 bucks, then you just have to have someone who can solder pretty well and TADA!! new plug in the amp.
Apr 01, 2009 | Kenwood KAC-728S Car Audio Amplifier
Broken RCA / phono jack - where to find new part?
You can buy Panel mount RCA (Phono) jacks at Radioshack, I think a 4 pack is less than 5 bucks, That should take care of your problem.
Good Luck,
Stay Classy
B.
Mar 03, 2009 | Jl Audio 1000/1 Car Audio Amplifier
DC input jack broken
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
Jack LaLanne Power Juicer
Hi smer67 - This is what it says on the official site about spare parts: See the back inside cover of the instruction manual for the spare parts order form or call: 1-973-287-5150
(MON-FRI 9AM to 7PM EST & SAT 9AM - 5PM EST). If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Aug 17, 2008 | Jack Lalanne Power Juicer (Stainless...
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
