Question about Breville Coffee Makers & Espresso Machines
Wish to access burr wheels in Breville Model CG12 coffee grinder
  • 8 Answers
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
My CCM grinder eventually stopped working altogether and I had to throw it away. Amazon comments says this is common. But while my grinder was working, it gave the same symptoms. This problem was caused by beans getting jammed and the outlet from the burr wheel being clogged. If that's the problem, cleaning it out is simple.
Posted on Jan 04, 2008
EsWorld
  • 1618 Answers
SOURCE: severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
Posted on May 14, 2009
  • 6 Answers
SOURCE: The on/off button comes off consequently machine isn't working
if you are handy the switch needs to be replaced. Soldering may be rquired and there is very little wire to pull. You can get a rocker switch at radio shack plus you need a triangular driver bit for base screws, It's really a poor design on a good grinder. You actually NOT have a switch and just hard wire it. I fixed mine for 3 bucks and an hours time
Posted on Aug 06, 2009
SOURCE: Need parts diagram of Mr. Coffee CG12 filter basket assembly
I found the missing vinyl washer.
Posted on Oct 03, 2009
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
How do I remove outer burr of Breville coffee grinder 800?
go to the manual! chances are you will not be able to remove the wheel. unless that is a maintenance procedure?!
Jun 25, 2014 | Breville Coffee Makers & Espresso Machines
Where does the water go
This is a COFFEE GRINDER. Designed to grind coffee beans to into a powder . This powder is then put in a coffee machine or a coffee peculator to brew coffee. DO NOT put water into the coffee grinder !
Dec 19, 2010 | Breville Conical Burr Coffee Grinder -...
My Breville BCG450 coffee grinder won't turn on and i have the bowl in place. Can you help me?
I sometimes forget there's an on/off switch on the back of the thing, since I mainly use the button on the side.
Dec 28, 2009 | Breville BCG450XL Manual Burr Grinder
Severe clogging
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
I cleaned my Breville grinder and tried to put it back together but the bean container will not fit back in. Please help.
This might be it. On the bean container there is a white dart and the word 'align'. The same dart and word appear on the top of the grinder. Align the two darts and the bean container should drop right in.
Dec 13, 2008 | Breville Conical Burr Coffee Grinder -...
Coffee Makers & Espresso Machines Logo
177 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
