Question about Yamaha Dtxpress Iv Special Electronic Drum Set
Bought a used dtxpress set pre-pogrammed.
I tried experimenting with the different sounds and lost everything. I need to know how to reprogram my set from square one. Please help!!!!
  • Anonymous May 16, 2009
    bought a used system, played for a little bit. now it only play back the midi. can not get back to the drum playing mode. anybody know how to set it back to normal? please help????? Thanks so much in advance
    President:
  • 1,138 Answers
The info is on pg.35 of the drum owners manual at http://www.dtxperience.com/dox/dtxp4_en_om_b0.pdf. Hope this helps.
Posted on May 15, 2009
Can I sign four toms to my dtxpress iv? thanks Arpi
Yes you can my friend. You can even have up to four more I believe. Please read here that everything is easy to understand:
http://www.arrangerworkstation.com/forums/showflat.php?Cat=&Board=DTXpressIV&Number=441199&page=&view=&sb=&o=&fpart=1&vc=1
Take care and enjoy your DTXPRESS IV!
Nov 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
The kick pad on my DTXpress II stopped working, and I have no idea how to troubleshoot (and am not eager to take it apart). I bought a new (used) one, and that doesn't work either. Thanks for any help!
First try connecting one of your other pads to the one for the kick. See if you can trigger the kick sound from it. IF you CANNOT, then there is a problem with that input OR the setting in the box.
These devices are NOT magic. They typically use a piezo disc sensor similar to those in some musical Christmas cards.(note that some of those now use small speakers.
the piezo discs can be caused to vibrate if an AC signal is applied, or they can generate a voltage when compressed.
IF the problem is in the kick trigger, you might as well CAREFULLY take it apart. You will probably find the disc is glued or was glued to the back of the rubber pad... The problem SHOULD be obvious as well as a solution... it will likely be broken gluing OR a broken wire... But do this ONLY if you veriify the problem is in the trigger and not the box input.
The trigger ONLY generate a voltage pulse of varying amplitude which then goes to the box which is where the sound is actually generated.
Apr 02, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Window display not functioning
You need to use a transformer type voltage convertor.
DO NOT use the type for converting 220 down to 120 for hair driers.
The voltage should NOT be a problem as usually these will operate down to 100 volts. If the keyboard is sounding correctely, that would indicate there is NOT a problem with voltage.
It is LIKELY that the connections to the LCD were damaged in shipping. There are many, many connections to the glass assembly and if dislodged will have lines across the display.
Repairing this is usually not something one can do unless very experience in electronics.
Mar 12, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha dtxpress iv standard
try a wooden snare, a light kick drum, the most natural hi hat you can find, some soft cymbals and a selection of wooden and metal percussion instruments.
Dec 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
Aug 26, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Problems with DTXpress III special bass drum pad
If you are comfortable with working on it and the warrantee is up try taking the pad apart to see if the piezo element has come loose from its mounting or if the solder joint is loose. If that isn't the problem save your settings and initialize the set according to the instructions in your manual.
Aug 09, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXPRESS IV SPECIAL changing cymbal(crash) sounds?
hi,
the right crash is a '3 zone pad' (notice the semi-circular groove around the front edge of the pad).
this means you should get a different sound from the bell, the main area of the pad, and the front edge.
In order to mimic a real crash cymbal, the 'crash' sound comes from hitting the edge of the pad.
In reality, there are ribbon switches (like mobile phone keypads) underneath the bell & edge areas of the pad that detect hits to these areas.
Oct 14, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
159 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
