Question about Epson Stylus CX5400 All-In-One InkJet Printer
Green, Green When I print photos I get a greenish hue all across the picture. I've changed cartridges, cleaned and aligned the heads. What's going on?
  • 2 more comments
  • Wiisa Nov 07, 2007
    I recently purchased a new pc with windows vista. I have not used the printer in about 6 mos. I changed all the ink. I cleaned the heads several times. My copies are green. I cannot print a test page it worked at first.
    the connections look good .
  • okedo Apr 12, 2008
    Having th same problem with photos - keep cleaning head, nozzle, everything and nothing works... very frustrating
  • andreamylo Jun 03, 2008
    everything i print out is red have done all the usuall when print out test page the microsoft window colour are not quite right i get from left to right/top to bottom red, yellow, pink, orange what is wrong and how do i fix it
    dont understand the solution given to the previous problems stated
**** it! green green green green
Posted on Aug 29, 2008
  • Epson Master
  • 705 Answers
Have tried to see if you can hold of a colour profile from epson for the machine? This could make a difference.
Posted on Jun 03, 2008
2 Suggested Answers
SOURCE:
watugot
  • 290 Answers
SOURCE: green hue
I am not a printer expert, but since none of them have jumped on your question, I will try to help. I had a similar problem with my Dell awhile back and found out it was a problem with the paper. First, try printing a picture using plain copy paper and see if it has the green hue. If not I would think the printer and program are ok. Make sure you are printing on the glossy side of the photo paper(some of it is hard to tell the difference) and that your printer preferences are set for the correct type of paper you are using. Please reply to let me know what you find.
Posted on Oct 10, 2007
My pictures are printing with a purple hue. I
You still have some clogged heads.Head cleaning once is sometimes not enough to clean your heads properly, especially if you are using 'compatible' ink cartridges. You need to clean your heads again, and possibly still again, until your test print pattern produces the correct colours.
Jul 10, 2010 | Canon I960 InkJet Photo Printer
Green hue
Oct 10, 2007 | Epson Stylus CX5400 All-In-One InkJet...
HP D7260 can't print color in black & white only - greenish hue
I am having the same problem, printing photos I took of the moon thru my telescope. Any solutions?
Jul 01, 2009 | HP Photosmart D7260 Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Excessive Yellow ink use
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Jan 24, 2008 | Office Equipment & Supplies
Color problem
What does a nozzle check pattern show? Are there any gaps in the pattern?
As a first port of call I would suggest you follow the instruction in my previous posts about under head cleaning. This can solve all kinds of issues with print quality and even if it does not sort your machine, you know that the head is clean and the nozzles are clear. Read this post
If that does not get you on the way, post the results of the nozzle check and we will see where to go from there.
Oct 13, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Changed ink cartridge, now printing with green hue
check the magenta cartridge is it not dry or try to clean the magenta cartridge nozzle and see. bye
Sep 24, 2007 | Canon I960 InkJet Photo Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
149 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
