Question about Cell Phones
Hi i just got a usb cable ,but once i plug it in what do i need to do to take the pics from it to my computer? i have windows vista.
  • toni_deyo May 11, 2009
    ok i pluged it in and the driver then load but now what .do i need to set the phone setting on something .cause i can go to camera but nothing happens..so i know im doing something wrong or have a setting wrong just dont know what .can u help?
    President:
  • 272 Answers
Turn the camera on with mode set to send. Vista will do the rest.
Posted on May 11, 2009
Need to transfer pic from my pantech to my hp laptop?
On most smartphones, once you plug in the USB cable to the phone and computer, the phone appears like another disk (D: or E:, etc.) on the computer, just like what happens when you plug in a USB key.
Once you've done that, explore around or use Search to find all the .jpg (picture files).
To copy the pictures, open My Pictures. Then drag the .jpg files from the phone window to the My Pictures window.
Jan 07, 2015 | HP Cell Phones
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Hi, I can't get my scanner conected, it was conected, turned it off ,now can't get it to work. ion PIC2pc. Thanks Nan
Hello.
Be certain that you followed the step-by-step instructions (From ION Support):
1. Turn on the computer.
2. Insert the installation CD into the CDROM
drive and the installation menu will appear. *
3. When you see the installation menu, click Install Driver.
4. Follow the on-screen instructions.
5. When the driver installation is complete, click BlazePhoto to install the software.
6. Follow the on-screen instructions.
7. If your computer does not have DirectX 9.0 or greater or Adobe Reader, click those items to install them. (If your
computer is using Windows XP Service Pack 2 or higher, Windows Vista, or Windows XP Professional, this is not
necessary.)
8. Click Exit to close the window.
Note: The first time you connect PICS 2 PC to your computer, wait a few seconds until you see a dialog box
that says "Found New Hardware" (this means the computer recognizes the PICS 2 PC). After you see this,
PICS 2 PC is ready to use.
If you followed the above instruction and still have a problem, reinstall (first, Remove from Add/Remove Programs) the software and be certain that the USB cable is snug.
If your computer is not recognizing the ION PIC2, be certain that your computer has a USB 2.0 port. Check your Device Manager to verify what USB port.
If still a problem, what error message(s) are you getting ? What operating system software (Vista, Windows 7, etc.) ?
Hope this helps.
Jun 28, 2011 | Office Equipment & Supplies
How do i put the pictures onto the computer using the USB cable??
If you have a computer running Windows XP, Vista or 7, just plug it in to the computer and turn camera on. The computer will automatically install the camera. Then just go into Windows Explorer, and you should see the camera named there. Click on it and get your pics.
Aug 09, 2010 | Disney Pix Max Digital Camera
What usb cable will download pics to my pc from a Sony
Consider NOT using a USB cable.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 30, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
How to put pics from phone to computer
First you will need data USB cable for your phone and you can get that in most cell retail stores or even online stores. Once you have this plug in cord in to the phone and then pc and some of the Operating systems will open it on its own and on some if it does not open with in 2 min just open my computer or just computer on vista and windows 7 and it will be a removable storage. Right click and click explore and just go through folder until you find pictures. Once you find then just select them, copy and paste on to pc.Hope this helps.
Feb 23, 2010 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Panasonic lumix camera fz20eb unable to upload pics to toshiba laptop with windows vista
You should be upload pictures using a USB cable even if you do not have the additional sofware. Once you plugged in your camera, it may take a few minutes for the computer to register a new device and you should be able to view pictures using the Vista popup or in my computer from the "new device"
Apr 21, 2009 | Panasonic Lumix DMC-LS75 Digital Camera
Photo transfer to pc
hi there Wellcome to FixYa once you have installed your pc suite for your phone plug in the usb cable to your phone and ur pc should see your phone as a storage device and then you are able to go in to the phone like a hard drive and take pictures from it, also if your phone has blue-tooth you may want to get a blue-tooth dongle for your pc as this makes it a whole lot easier to send and receive files from your phone to the pc
I do know that vista has issuses with phone pc suites and may not work at all but this is only on windows vista if you have windows xp you should be fine , also if you do have vista bluetooth is the only way your going to be able to take pictures of your phone
Hope this helps
Feb 06, 2009 | Samsung SGH-G600 Cellular Phone
My computer doesn't recognise my camera.
Hi There, If you are using Windows xp or vista, you probably don't need special drivers, the computer should recognize what you are trying to do. Just in case, check your owners manual for computer/download info. Also check your usb input or try another usb input to make sure they are working. You could also try a friends computer to eliminate trouble with your own. If all else fails, you could purchase a usb multi- card reader to down load your pics, around $20.00.
mr cicmo
Dec 25, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Need to download pics from camera
You should be able to plug in the USB cable to your PC and let Windows do the rest. Provided you have MS Windows
Sep 16, 2007 | Cameras
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
