Question about Tivo Wireless-G USB Network Adapter
Windows drivers for Tivo Wireless-G USB Network Adapter?
I no longer use Tivo. I have this Tivo Wireless-G USB Network adapter which I would like to use in a Windows wireless LAN. $('ctrl_rater_ctrl_unit2_rdYes').observe('click', function() { selected_ctrl_rater_ctrl_unit2 = 1; checkReviewsMarked(); }); $('ctrl_rater_ctrl_unit2_rdNo').observe('click', function() { selected_ctrl_rater_ctrl_unit2 = 0; checkReviewsMarked(); }); Are there any windows compatible drivers available? Regards, Kenneth Percival
$('ctrl_rater_ctrl_unit3_rdYes').observe('click', function() { selected_ctrl_rater_ctrl_unit3 = 1; checkReviewsMarked(); }); $('ctrl_rater_ctrl_unit3_rdNo').observe('click', function() { selected_ctrl_rater_ctrl_unit3 = 0; checkReviewsMarked(); });
var selected_ctrl_rater_ctrl_unit1 = null,selected_ctrl_rater_ctrl_unit2 = null,selected_ctrl_rater_ctrl_unit3 = null; function checkReviewsMarked() { if (selected_ctrl_rater_ctrl_unit1 !== null && selected_ctrl_rater_ctrl_unit2 !== null && selected_ctrl_rater_ctrl_unit3 !== null) { $('btnctrl_rater').disabled = ''; $('btnctrl_rater').className = 'c_sub_small sub_enabled'; } } function checkAndSend(obj) { if (selected_ctrl_rater_ctrl_unit1 !== null && selected_ctrl_rater_ctrl_unit2 !== null && selected_ctrl_rater_ctrl_unit3 !== null) { setRate(selected_ctrl_rater_ctrl_unit1,selected_ctrl_rater_ctrl_unit2,selected_ctrl_rater_ctrl_unit3, function() { window.location.href = window.location.href; }); } }
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Super G 802.11g/b
ok look in device manager down the list to your wireless card and see if it is listed, if so check that there is not a red cross on it, if so right click and select enable. if a yellow exclamation mark driver not recognised with card. If it is listed and you are unable to enable it restart the pc and press F2 or DEL to enter your bios and on the peripherals menu, see if the wireless controller(if it is built in card) is enabled. If non of the above works, then the code 10 would normally be refering to a faulty peice of hardware.
Posted on Mar 18, 2007
davidgut_99
  • 33 Answers
SOURCE: Is a downloadable driver available for the tivo
Just Hook Up to Tivo Unit. No Driver is Needed
Posted on Jul 05, 2010
davidgut_99
  • 33 Answers
SOURCE: How can we interface a Linksys Wireless-G USB
Please Check the Adapter on Tivo.com Website.
Some Linksys models are not compatible with Tivo Boxes
DriverAg0100 Driver Download
You don't need a driver for the Tivo AG0100... you plug it into one of the USB ports of a TiVo DVR and configure it from the Settings & Messages -> Settings -> Network -> Change network settings menu in the TiVo DVR.
Jun 10, 2013 | Tivo AG0100 Wireless G USB Network Adapter
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Tip
I cannot locate the disc for my TIVO, and am trying to get the TIVO wireless...
Right-click the "Network" icon in the Windows Notification Area at the bottom right of your desktop, then click the "Open Network and Sharing Center"option from the menu.Click the "Change Adapter Settings" link and right-click your "Wireless Network Connection" icon, then click the "Properties" option.Click the "Configure" button, then click the "Advanced" tab.Click the "Channel 802.11n/b/g" option from the menu, then type a new value between 1 and 11. Click the "OK" button to save the changes and close the dialog box. Update Wireless Adapter Driver Right-click the "Network" icon in the Windows Notification Area, then click the"Open Network and Sharing Center" option from the menu. Click the "Change Adapter Settings" link and right-click your "Wireless Network Connection" icon, then click the "Properties" option. Click the "Configure" button, then click the "Driver" tab.Click the "Update Driver" button, then click the "Search automatically for updated driver software" option. Windows automatically searches for and installs the latest driver for your wireless adapter.< Click the "OK" button on both dialog boxes to save the changes and close the window.Update Router's Firmware <li>Click the "Start" button, then click the "Computer" l Click the "Network" heading from the left pane, then double-click the"Internet Gateway Device" icon under the Other Devices section. Your default browser launches to the login page of the wireless router. Type the username and password, then click the "OK" button to log in. Click the "System" icon and then click the "Update" option. Click the "Yes"button when the wireless router configuration tool asks if you wish to search for the latest firmware on the Internet.out of the router's configuration utility boost-wireless-adapter-signals.
on Dec 31, 2010 | Tivo Wireless-G USB Network Adapter
Add driver for window 7
Microsoft Windows Vista and Windows 7 does not include native drivers for the Del True Mobile 1450 USB Wireless adapter and there will be no 1450 USB Wireless adapter drivers available from Dell that are compatible with the Windows Vista or Winds 7 Operating System.
There will be no support for the Dell True Mobile 1450 USB Wireless adapter in Windows Vista or Windows 7.
For 1450 USB Wireless adapter drivers for Windows XP 32bit Click Here.
Sep 15, 2012 | Dell 1450 (D1450U) Wireless Adapter
I want to get the TIVO AG0100 wireless adapter. I do not have wifi in my house so will it still work? I'm not planning on getting wireless for my computer.
Dear,
Since it's an adapter and not a router, it will not work if you don't have a previously installed wireless network.
You might buy a wireless router and connect it to your computer and use Tivo at the same time.
Jul 22, 2011 | Tivo AG0100 Wireless G USB Network Adapter
Tip
How to Boost Wireless Adapter Signals
on Nov 02, 2010 | Tivo Wireless-G USB Network Adapter
We have lost the original disc that came with the TIVO and I need to get the Tivo wireless network adaptor set up on our wireless network. How can I do that without the disc, is thee anyway around that ?
The disk us usually not necessary. If you are using a series 2 TiVo you just plug this in to the back of the TiVo and it will recognize it. In the TiVo menu find Network Settings. If you select change network settings it will ask you to select your wireless router and ask for the password to your router if you are using one.
Tivo Wireless-G USB Network Adapter Logo
1,020 people viewed this question
Top Tivo Computers & Internet Experts
David Payne
David Payne
Are you a Tivo Computer and Internet Expert? Answer questions, earn points and help others
